Hey forum I just have a couple question about boost spiking, all help is appreciated. I hooked up an ebc on my friends stock gtst r33. Now only mods are the ebc and a pod everything else stock. I set it for lo boost 10psi and hi boost 12psi.
1. When the car accelerates should it not be boosting up to 10 psi as long as you are on the throttle not all the way but accelerating? I get the 10 psi but it doesn't hold it as long as i feel it should it just gets there and then starts to fluctuate.
2. The ebc has a warn function to limit boost when spiking, which i set to 15psi. It activates this function. Not on accelerating but I feel on gear changes. The ebc has a boost guage as well and it doesn't read 15psi at all. Took the car on a run to test the settings and the highest i saw during the driving is 10.4 but it also has a last and peak function that allow to view the highest boost ever recorded and the last boost you did before turning the car off when looking at that I see where the car did 16.4psi but I did not see it during the run. What do u feel is the cause of this I told him to get a full turbo back exhaust and he would see the boost remain constant. I was also thinking to just set the controller at a higher warn function to stop the spiking feature seeing as its only during the gear changes. Was i correct?
https://www.sau.com.au/forums/topic/164865-boost-spiking/
what ebc is it.
If it is a gizzmo and you are spiking, your responce is set to high, this will couse exactly what you are discribing.
A free flowing exhaust doesn't fix boost spike, it actually makes it worse. As the exhaust is free, and it's easier for the gas to go through turbo then the wastgae, and hence spiking.
Do a search for WogsRus as author and Gizzmo as topic, i have posted a few replies for simmilar problems.
https://www.sau.com.au/forums/topic/164865-boost-spiking/#findComment-3054028
what ebc is it.
No its P.I.T Boost control unit. Ill try to explain it better, doesn't spike when Im driving it spikes on the gear changes and that activates the warn function and it doesnt hold boost i have seen it get to the desired setting of 10 psi but it doesnt hold it, the minute it gets there say around 4000 rpm it immediately drops off to stock boost numbers and thats in third and fourth gear. I was figuring that it was suppose to hold boost on acceleration from about 3500rpm to around 5000rpm or so, the stock boost guage is constant but the reading on the ebc fluctuates. Any one has any suggestions
https://www.sau.com.au/forums/topic/164865-boost-spiking/#findComment-3059330
You installed an EBC on a stock car?
Not the smartest thing i've heard of :)
You ideally need to get a full exhaust. Your trying to force more air though something that already has problems, and your just adding to it.
It sounds to me like you have a couple problems. The setup of the boost controller being the main one, thats if the EBC is even working correctly.
Its time for you to go an see a professional i think
https://www.sau.com.au/forums/topic/164865-boost-spiking/#findComment-3059459
Not the smartest thing i've heard of :P
Yea you are right but if that is what the man wants to do I'll assist anyway I can.
https://www.sau.com.au/forums/topic/164865-boost-spiking/#findComment-3061033
Yeah true point, tell him to help himself and get an exhaust :nyaanyaa:
What do the EBC instructions have about it all?
LOL lol lmao :laughing-smiley-014: thats the first thing I told him to do cause I made the same mistake, but you know how it goes first thing you want to do with a turbo is up the boost. Got hit with the more power bug I guess. THe instructions in the book are that it tells you to set the start boost function which is the boost at which the waste gate begins to open which they say should b set before the destination psi to avoid over boosting, have that set to 7psi, and then the gain function which activates how quickly or slowly the gate opens 100% fastest 1% lowest which I set to 48% I think. After a few trial and errors is how I got the numbers anything over 7 for the start boost on the low boost side and the ebc's boost guage goes above 10 at 7 once you are accelerating I saw it get to 10 but never above a couple a times. But it does spike cause I have the warn set at 15 psi and it activates. Like I stated earlier I never see it during a run but when i look at the peak and last boost its there plain as day so I figure it has to be that surge during gear changes. What do u think?
https://www.sau.com.au/forums/topic/164865-boost-spiking/#findComment-3061989
For the stock turbo on a gtst, i don't see why people even bother using an ebc. If you get a full exhaust and fmic, boost will increase a bit already. mine was running about 9psi with just those mods.
then i put in an r32 waste gate actuator, and boost went up to 11-12ish psi. no spiking, bolts straight on, looks stock, boost drops off less at the top end.
if you need one, i've got a spare one. i'd just sell the ebc off, because you can't really run more boost than the 32 actuator anyways on the stock turbo
https://www.sau.com.au/forums/topic/164865-boost-spiking/#findComment-3062268
    • Probably a smart choice to buy one vs build, purely for the motivation part as you said! Imagine the metal dust everywhere from grinding all the steel to build one. Ha ha ha!   Also, post a photo of your garage.   Mine is below, this is where I've been cleaning and have already half filled a caged 6*4 trailer. And this is after my cleaning expedition mentioned previously... The middle normally has a car in it, but I'm dumping things in the middle as I sort through them. And poor skyline was dusty and has had the lightest few drops of rain and now it looks atrocious and needs to be dragged back out and washed thoroughly! And yes to the right is technically another bay, you really can only see 2 bays out of 3 in this picture.
    • It's more like on average the things I see a lot of things going wrong. Yes, usually the people who reach out are the ones who are having problems but on average it feels like mechanics and tuners here aren't really competent. I swing between thinking my standards are just way too high and wondering whether people really are just this dumb. I just had the strangest 10+ reply argument on a Facebook group over someone insisting that the factory R34 GTT boost control solenoid reduces boost pressure to 5 psi when it's on and raises boost pressure to 7 psi when it's off despite showing the exact plumbing in the factory service manual and the solenoid behavior detailed in the FSM.
    • I steam cleaned my near new set of volk gtc wheels 14 years ago and farrkkked them lol. The clear coat cracked like spider webbing in several areas. Lesson learnt don't do that. 😭
    • If you don't touch the CAS, then you're fine.
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
