HEHEHEHE
Are you from South America or The middle East???
That is the only place I can think the R31 2door had these engines.
The engine they came with in Japan was the RB20DET
Personally if I had a disposiable income if pick an RB26DETT from a skyline GTR. (pull it out of your R34 because we all know the R31 is a better car) :)
HEHEHEHE
Personally if I had a disposiable income if pick an RB26DETT from a skyline GTR. (pull it out of your R34 because we all know the R31 is a better car) :P
I am from middle East !!
I know The engine they came with in Japan was the
RB20DET but in the middle East 3.0 single cam
engine with carburator :P
BUT why do you think r31 is A better from GTR ??? :)
^^ its ok Epolly, now that you have proved you own the cars you mention im sure you will become a respected member of SAU.
We just had school holidays here in australia and unfortunately many kids come on board and talk/type crap all day long, there are many people on here that dont even have cars that pretend they do so it takes a while to pick who is worth answering and who is worth ignoring :huh:
You will thank me for asking for photos of your car one day, that just proved to everyone that you arent full of shit and you have some real questions to ask here...
Good luck bkc, I hope you reach 650hp and get the R31 beefed up.
This guys deserves the help, look at his ride, its a beast. both of them.
Edited by Pauly33GTS-t
thank you Pauly33GTS-t' :D
I wish to deal with men! Not silly comments and replies are not useful!
You dont even own one traitor!
ha! and whose fault is that huh!!!? lol
you own one, and talked me out of it! talk about traitor! lol
See this site you like, perhaps! :whistling:
http://www.r31house.co.jp/ ;);):thumbsup:
we have so much in common
we both like r31s
and we both like men!
hi5!
    • You would need to paint your hardtop again though
    • I have an old R32 in the shed that hasnt moved much in the last few years and probably should see the light of day. At one point I had a Nismo 1.5 centre put in the rear diff. It is a clunky nightmare POS of a thing on a good day. To make it less painful the initial torque setting has been put on the minimum (7.0kgf-m, mid is 9.5, high is 14) and the oil changed out to something more slippery. But it is still awful and ruins the vibe of the thing. So my questions are: Given I have the original parts sitting in a box somewhere would it be better to rebuild the thing again, reverting to more purity? Is there a standard kit or do you just go and replace the friction plates etc and shim it the way you like it. How much initial torque does the standard R32 rear diff have? Or does the Nismo disc kit offer a better solution - the caveat being the initial torque for both options appears to be higher than the clunky 1.5 way. There appear to be two Nismo disc kits: 3843S-RS520 for 8kgf-m. 3843S-RS521 for 12kgf-m. Or is the easiest solution to reshim the Nismo diff to make it looser?
    • It is not a dual mass flywheel, so you will get some gear noise on a BNR34 unless you deviate from the OEM fluid spec and run a thick gear oil like what Nismo recommended for a while. Unfortunately I have never weighed the flywheel by itself prior to installation but it is not that light. It's probably an 8-9 kg flywheel. OEM BNR34 dual mass flywheel is like 14 kg which is kind of hilariously heavy.
    • Got around to installing the Tomei Cam Cap Studs and the Hypertune cam baffles/splash guards. Unfortunately, I was not aware that the cam cap studs do not clear the stock RB25 internal cam cover baffles. Some research found a set from boostdoc which includes a replacement cam cover baffle and full length cam baffle + tools and fasteners. but I'm not keen on re-buying what I have already bought. So the plan is to take the hard route and modify the existing cam cover baffles to clear both the cam cap studs and the hypertune cam baffle plate. I assume there must be people who have gone through this even just to convert from cam cap bolts to cam cap studs? If so any tips would be appreciated. Otherwise I think I will mark where the cam cap studs foul, drill clearance holes in the cam cover baffle, and remove the cam cover baffle oil returns to clear the  hypertune baffle plate. I will also need to remove the baffle and drill and tap threads to bolt it back on so i can clean out any swarf. Fuel tank foam as extra cam cover baffling?
    • The incoming weather event seems to be affecting people in weird ways....🤣 And no, whilst there is some fancy engineering going on, I have no real interest in anything rotary really I had a Capella in the 90's, the rotary engine is way to temperamental, and extremely thirsty for my liking  If I won lotto and wanted to waste a ton of cash, a boosted K-swap would be what I would look at, until then, the N/A MZR2.5 will be at home in the engine bay of the NC A build like this, just without the idiotic street pulls and skids would be interesting to waste a huge amount of money on https://youtu.be/EgqAoVtUD1E?si=n3_umivrUPP8C9Cs
