it will be a plain remap, so no one can touch it unless they have remap tools for ER34
dr drift in melbourne might be able to sort it out otherwise theres a dude in sydney who can do them (dont know name sorry)
ideally get a locall supproted ECU so you can goto any tuner.
but as far as bang for $ it might be ok, it will have the limits all removed and maybe some more timing.
its probably rich as all hell as well (assumption)
what are you talking about mines computer? lol. why would impul buy a mines computer and re map it? It's a standard nissan computer re-programed by impul. if you are referring to the painted over sticker, that says "nissan re-manufactured ecu" or similar. lol. mines.
personally I think anything over about $100 is too much to pay, unless you know exactly what it was tuned for, in which case $300 would be ok. but you are far better off just buying a pfc or similar.
  • 1 year later...
Hey 8110,
I realise this thread is a little old though maybe you havent yet made any decisions. Heres attached a pic of my ECU that came in my car. I also have a neo afc and running 9psi as we have some detonation issues im told. (new to this) the only other mod is a blitz 3" catback. now although the dyno's arent accurate and a normal day up here is relatively hot (32+ degrees C) only acheived 162.5kW im looking into a powerFC as my tuner tells me this ecu is in a foreign language an doesnt seem as though he can do anything with it to further modify. Now i'd rather know that my ecu isnt limiting my cars drivability in anyway before i go ahead with future mods.
Hope this helps
cheers :)
Is that for a GTR? Or for something else?
I got 156 AWKW (not on a good day), on my first dyno with a MINES ecu.
After tuning with a PowerFC and high flow CAT and panel filter, adjustable cam gears >240RWKW :(
I'd recommend getting rid of the non-tunable ECU and getting a PowerFC or similar.
Mentioned it before but regrap the plugs and if youve got det issues its enhanceing the timig thats ok cause safc works well at retarding the timing down low.
To answer your question it would not be limiting your cars ability to would be a more aggressive tune compared to stock, the problem might be the tuner too. get someone to check your timing it should be 15 (from memory) and it might be your fuel pump shitting itself.
It really could be a million things but in my opinion it will NOT be the ECU.
But in saying that a power fc is the best upgrade option atm and I have just bought that, they are shit expensive but bang for buck they are the best increase in power the for sale section has a few for view now. If you want to go faster this is the key!
Edited by DECIM8
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam camp bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
    • I had the same previously, and it really shits me. They just run off red book averages or whatever as the maximum insured, there are never good quality cars available to buy for anywhere near those prices. I don't even understand why they do it. Sure having a customer overinsure then false claim is a risk, but how often does that really happen in the world, 1%? 0.1%? On the other hand, all 10-20% above redbook listed prices and charge 10-20% higher premium, surely that is more profitable for those cockroaches
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
