I have just had it dyno tuned by Matt Spry on the Gold Coast at 185 rwkw. His Dyno is low so the figure is more like 195 rwkw. Engine is in good condition, so is the body and interior. And anyone who has seen the car will agree its a sexy, no work needed, skyline.
Ok onto the mod list:
Wheels brakes suspension steering:
JIC Rear Adjustable coilovers
GTR Fronts (rears will also be supplied)
17" single piece Avanti dark chrome drift rims with GT Radials on Front: 235/40 Rear: 235/45 (can also supply 2 more)
GTR brake calipers
Front: Cross drilled, double slotted performance disks with performance pads (another set of pads can also be supplied)
Rear: GTR disks with same pads
1.5 Way Cusco LSD
Short shifter kit with Heavy duty clutch
Exterior:
Calsonic Blue custom paint.
Darkest legal tint available
GTR grill, skirts, front bar and bonnet
APEXI drift wing
10 000v High intensity white Xenon headlights and blue parkers.
Interior:
Custom Blue/black interior
GTR seat
MOMO Steering wheel
IMPUL Gear stick and custom surrounds.
Blue dash and interior lights.
Mongoose 5 point immobilizer and alarm
Swoosh Boost gauge
Turbo Timer
Not sure on the Stereo at the moment, but will most likely be:
Sony Xplod head unit
6 1/2" Splits and 6" rears running through 2*300W Amp
Engine:
3 1/2" Turbo Back exhaust with High flow cat and 5" Cannon
FMIC 600*300 with 3" stainless steel piping.
HKS Alternator
APEXI Pod filter
550hp Fuel pump
SARD Fuel Pressure Regulator
Z32 Air flow meter
Turbosmart Boost Controller
Chipped ECU with APEXI SAFC2 (Super Air Flow controller)
Engine was rebuilt at the start of last year. New parts consisted of majority of internals, including gaskets, pistons etc. Christmas also saw new plugs, battery, and a clean up of anything else that needed work. Injectors have just been fully cleaned, serviced and flushed.
I think thats just about it. I'm sure there more but can't remember. I can supply a bucket load of reciepts and the dyno sheet along with manuals etc for things like the SAFC2. Car is in near perfect condition and runs like a dream. The only reason I'm selling is because I really want an R34. Running Caltex Vortex and Penrite semi-synthetic and been serviced regularly.
There are a couple of glitches with the paint work - scratch on the rear left side from the Container when it was shipped over, but they can be touched up pretty easily. Engine and interior are in great condition.
I'm selling for $17 500 depending on what you want with it. For that price you will have the rego till Aug, a second set of racing brake pads, second set of tyres, pair of rear GTR shocks, second MOMO steering wheel and anything else I have sitting around for the car.
If your interested msg me on here or call me on 0408706117
Pics up tonight
Edited by Anakha
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
