  • Replies 87
did the skyline have cheap tyres and no grip? driven by a myopic orangutan?
ahh.. who knows hey? I hear so many of these stories on so many forums
if it was the hills ( windy ) and the celica had kick arse suspension and super grippy tyres
and the skyline had crap handling and no grip then who knows.
https://www.sau.com.au/forums/topic/164902-my-mate-reckons/#findComment-3054958
more power does not mean a quicker car.
ive got a relatively light modded 180sx probably what 100-140hp?? f**ks me.
. ive beaten a 300 horsepower R32 GTR,
coz the driver just couldnt drive.. he was shithouse.
suspension, driver ability, tyres, brakes, weight, gear/diff ratios
alot of different things make up the argument.
https://www.sau.com.au/forums/topic/164902-my-mate-reckons/#findComment-3054966
There are just too many factors in this argument...
For a start the roads in the hills are all 1 lane each way and depending on whereabouts it is, there are very few places to overtake.
It also depends on the skills of either driver, as others have mentioned. When I drive through the hills I'm always over-cautious so I dont push the limits on corners etc.
BUT
if we assume the drivers have equal ability and the cars are as described, then the skyline would walk all over it. :whistling:
https://www.sau.com.au/forums/topic/164902-my-mate-reckons/#findComment-3055776
A 110kw celica beating a 220-240kw skyline thru the hills? Is this unheard of?
I hear about it, and see it, on a regular basis. Winding road driving is more about driver skill than the car's power output. And the willingness of the driver to push it.
On the weekend I blew away a Ferrari F430, 360 Spyder, 575M and 355 Berlinetta through the Nasho. I'm willing to bet he wasn't driving as close to their limits as I was, though.
I've outrun plenty of turbo modified Silvias and Skylines, as well as a range of sports bikes, in a stock Pulsar SSS when we were both trying. Recently I've been getting smashed by Civics, Integras, RenaultSport Clios and NA S13s in my light-tune 350Z when I've been going as fast (and sometimes faster) than I feel comfortable doing. I've seen a 180awkW WRX being tailgated by a 70rwkW AE86.
https://www.sau.com.au/forums/topic/164902-my-mate-reckons/#findComment-3056313
Ok the celica got a 7,000 dollar suspension setup at the best... apparently.
The skyline will have a SK kit, and 18inch Racing hart cr rims.
That's alot to spend on suspension alone, if it's a road car. What sort of Celica?
There's only a few tight & twisty roads I know of in the Adel hills where underpowered, lighter & nimbler cars could better a 200kw+ whale, otherwise I also say it's the driver.
https://www.sau.com.au/forums/topic/164902-my-mate-reckons/#findComment-3056670
depends on driver n plus depends skyline could easily slide the back tyres celicas bein front wheel drive should have it's advantages
use to drive a lil lancer with 215/40/17 and had really good tyre n suspension setup but could easily beat ma 34 now on turns
https://www.sau.com.au/forums/topic/164902-my-mate-reckons/#findComment-3056688
shit my R34 is non turbo auto and i have raced new v8s and munched them off the line and pulled away from them..... its all about driver ability in the end...... what the driver is willing to risk to get ahead and to win....... its as simple as that..... obviously the cars power and performance has alot to do with it but having higher horsepower dont mean ur gunna have a quicker car....... like i said my bog stock non turbo automatic 96.5Kw RB25DE has decimated 300+Kw v8s makes me scratch my head to this date but meh.... just driver ability in the end
https://www.sau.com.au/forums/topic/164902-my-mate-reckons/#findComment-3056860
Why would you even bother to write something stupid like that on the forums!!
Without any modification list on both cars and its history!! Which hills?
There are millions of factors involved.. The driver comes in to factor also!!
Was it raining that day??
and so on and on..
But who knows, maybe the celica has better handling..
I got my ass wopped by a NA r33 thru the hills once.. Comes down to the driver and suspension setup.. Pretty sure my mate had coilovers and sway bars.. Mine is stock..
So having a turbo car didnt mean shit.. Im sure if he drove my car he could have driven it 10 times better..
So yea.. maybe the celica could win.. but comes down to so many factors..
Edited by siddr20
https://www.sau.com.au/forums/topic/164902-my-mate-reckons/#findComment-3056872
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
    • sorry dude i forget about the forum sometimes. sent you a pm
