yeah I was going to use some 340mm rotors I have with the standard calipers. but now that I have these brembos i may as well use them. mainly because they have a larger pad, and should be a stiffer caliper.
if you do want to use 324mm rotors with the stock calipers I'd reccomend the UAS kit. Very, very nice brackets. and not a bad price either.
  • Replies 76
Posted Images
just so happens that the tread is alost right. just abit tight. so the tap makes it slightly bigger by about 0.2mm so worst case you can still use the calipers on a 34.
I'm not sure what you mean dave-o? you mean I can drill my hubs to take the 14mm bolts for the 34 caliper. and then if I ever wanted to go back to stock caliper I could just cut a new thread in my standard 32 caliper to accept the 14mm bolt?
here's a couple of dodgey pics I snapped just for you ronin. the gold is a bit camp, but I must admit they are a good looking caliper. If I thought I could get as good a finish as factory I would paint them black for sure.
yeah also missing rotors, lines, pads... no, I have everything. I just didn't take pics of it all.. there are no shims in the rear calipers as there are no pads in there.
as for you ronin... don't poke fun at my gold brakes. at least they are factory painted unlike all the cool people who paint their sumitomos gold to make slow witted people think they have brembos...
eug, yeah your black stockies look ok, but I don't like the finish on them (which is why I wont re-paint the brembos). It just doesn't look quite right to me.
Hmm interesting. I was always of the understanding that the pad in the Brembos on the Nissan was bugger all larger than that of the Sumitomo's. Any chance of a compare & contrast?
Gold: The new black?
Or
Gold: As camp as a row of pink tents?
yeah, I'll whip one of the pads out tonight and do a little comparo. it's not a massive size difference, but it looks bigger to me. god I hope there is some advantage as they are not that cheap! i'll cling to the faint notion of a stiffer caliper.
yip... it's impossible to get the same smooth glossy finish in black without spending some decent coin for temp resistant paint.
they get dirty anyway, so i wasnt too fussed.
yep, that's what I meant. i guess it would want to be to take advantage of the larger diamter rotor. :D
Well yes & no. It is not so much the diameter of the rotor as a whole, but more so the depth of the race of the rotor. See the attached photo for an ugly example of what the things shouldn't look like. You can see that there is a fair amount of rotor face not being wiped by the pad & also that the inside radius of the pad is quite a bit different to how it should be.
It is something to be a bit careful of when buying aftermarket calipers & rotors - particularly if you are mix & matching.
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
