Hippy he wins because he can drive very well(not saying some of the other cant). Jimmy races a V8 supercar twice a year and does it better than many of the other who do it all year, he has raced almost everything and has won in most.
Jim is an amazing driver, his caris supported by porsche australia and has the best local knowledge and experience of any of the competitors. he also has an amazing driver navigator set up with Barry Oliver.
But well done to the skyline an amazing effort, it looked extremelly well prepared and sounded amazing. had the chance to speak to steve and he sound like a top bloke. Lets hope for one better next year. munro how about u take down a gtr?
Nice effort indeed! Congrats to the driver too - did well to be that close to Jim Richards; a VERY experienced driver. Gee he's only won Bathurst 6 times :D
He used to race the R32 GTR too, back when they were introduced into the Aussie touring car races... along with Mark Scaife.
Well done tilbrooks and co. :D
Hippy.. Ok for 260rwkw in a R33 what do you need.
Nice turbo ~2300. recond. BB (Fit your self)
fmic ~1400 (Fitted)
exhaust ~1500 (Fitted)
ECU ~1600 (Fit your self)
fuel pump & reg ~550 (Fitted)
tuning ~i don't know umm ~300
Thats approx. - $7650
I remember when I was going to work my VS 5.0ltr here is what I was quoted.
170rwkw - Bit of head and cam work $1500
190-210rwkw - Major cam and headwork with roller cam, roller lifters etc. $5000
230-250rwkw - Supercharger close to $8000
So it evens out. I then added up is fuel consumption, insurance etc.
I wasn't able to insure the car with the roller cam or supercharger.
I would have then had to do a major upgrade on the brakes as honestly on the VS the brakes are total crap. They just don't pull up.
At the end of the day if you can handle not having that awesome V8 sound the Turbo is a little more economical and pratical around the shops local etc..
    • Yes. It's either "2 wires", or 1 wire, depending on how you look at it. It is the connection that ties the battery -ve to both the chassis and the engine. Every electron that goes in or out of the battery goes through those 2 small spots (on the inner guard and on the engine block). If those are not clean and tight, then shit starts to suffer. Yeah, but measure it again cold in the morning, after it has had hours to rest. You can't usefully test the charge state of a battery immediately after it has been running because the alternator puts a surface charge onto the plates that takes a while to soak in and balance out. It will always read higher, and potentially look properly healthy, when fresh off of charge. But hours later it can look a lot less healthy. It's also worth measuring the battery voltage while cranking, although this can be difficult with a typical DMM because the screem update rate is so slow on most of them. An analogue voltmeter is actually a better tool for that. If the voltage drops too far while cranking, it is a sign of a poor battery. Although I don't think we're necessarily looking for a weak battery here - just wanting to exclude it.
    • https://www.facebook.com/share/15ZMn5oXtc/ Updated Event (so its not private and can be shared easier)  Attempting to coordinate a big push of Stagea's to this years GTR Festival. Great event last year and hoping for the same this year.  Discounted tickets 20% off for their various tickets until the 3rd of Feb Monday. Drags, show and shine etc.  I've emailed them to ask to set a location aside for the Stageas for the show and shine - they are happy to do so if we can get them numbers, I'm happy to keep track of that. Entering as Nismo category.  I'll be road tripping up from Melbourne, would be cool to convey if people are interested, maybe there is SAU convoys from each capital? If you have ideas about that let me know.  https://gtrfestival.com.au
    • Does have series 2 airbag steering wheel and passenger side airbag also.
    • Do I have a series 2 or has someone spent money to have a series 1/1.5 look like a series 2? Everything I have read says the series 2 came out in 1996. I have a car manufactured in December 1995. The exterior, engine and interior are all series 2 other than the dash facia is series 1. Paint code is also kr4 that I believe is only available on a series 2. I have a VX Vehicle History Report and it says Grade: GTS25T TYPE M2 Manufacture date: 1995-12 Make: NISSAN Model: SKYLINE Body: E-ECR33 Grade: GTS25T TYPE M2 Engine: RB25DET Drive: 2WD Transmission: F5
    • I went to Repco to get them to test the battery using their tester (not a volt meter), alternator shows 14.3v when running, and when the car was off after the it was on full load I think it was 12.6v but the guy said it was all good. Terminals are all clean, no corrosion. Though I coulda sworn when I tightened up my alternator belt the car idles a bit higher and the steering wheel shakes a bit until it's warmed up. I wanted to confirm for the earth cable/s, are you referring to the 2 wires that are bolted onto the frame rail under the battery? I might be overthinking this a bit.
