For sale: 1989 Toyota MZ20 soarer GT Limited
Asking Price: $6000 firm
Killometer's: 130 XXX
Manual or Automatic transmission: Automatic
Engine Type: 7M-GTE
Modifications: Turbo Timer(not connected),
Complianced: Yes
Road Worth Certificate: N/A
Registration: Yes, will be sold with rego
Crash History: No Accident History - Inspection Welcome
Other Comment's about the vehicle: Have never seen a mz20 in this type of condition. near perfect from everyone that has been in it.
Blown headgasket, very minor blow out, and no other damage was sustained.Cheap to fix, think I got quoted around 697 with everything. But dont have the $$$ to pay for this, so will be sold unfixed
Pictures can be seen on nissansilvia.com
link is here
http://www.nissansilvia.com/forums/index.p...howtopic=222925
Contact detail's - Lachy 0439 815 851
Edited by lachy 180sx
https://www.sau.com.au/forums/topic/164934-mz20-gt-limited-immaculate/
yeh they blow pretty easily, but with a decent strengthed head gasket ull be hard to blow it again
get a hks 250dollar head gasket and ur laughing and labour is cheap if u remove the head urslef, only a couple of hundred
come on,buy it
you know u want to
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
