Ok, i figured other forums i frequent have them as well
please post as many specs of your wheels as possible
width and offsets being the MOST important
Picture from the side straight on, and one from the front straight on (to see if they stick out, or sink in for fitment wise)
ill start
Stock M35 wheels.
15mm spacers front and rear to clear GTR brakes
225/50/17 tires
17x7 id imagine is waht it looks like
Work euroline
18x9 -5
18x0 +20
235/40/18
above is with stock fenders
below is with midified fenders
Work Emotion XD9
18x9 +20 all around +20mm spacer on the front
225/40/18
please contribute
https://www.sau.com.au/forums/topic/164936-post-your-wheelstire-size-and-specs/
  • Replies 67
17 x 9 - Standard R33GTR wheels with 245/40/17's
Pictures are at 340 mm front and 330 mm rear, which was too low. It's now at 355 mm front and 350 mm rear, much better ride and handling.
:D cheers :(
  • 4 weeks later...
18x10 +20
dont get a 10 in the rear unless you get at LEAST a +10
but hten you will haev to do an agressive roll and pull in the rear.
anything less will hit your coilover.
18x10 +20
Your using 235's on 10 inch rims as per per your first post?
They would look mega stretched?
A "normal" person would use a smaller width rim and run the correct width tyre for comfort, looks, handling and safety
am i normal?
I use a 225/40 on a 9 inch wide and a 235/40 on a 10 inch wide
its about clearance, the stretch in the sidewall allows you to run a wider/lower offset without fear of rubbing so when the camber changes in a turn, it acts like a circle and not a square like a normal tire
am i normal?
NO :thumbsup:
That's why you should explain or clairfy when posting esp when people are asking a question about a topic they do not know anything about. Otherwise someone is going go and buy a set of wheels too wide or the wrong offset and have to beat the shit out of the rear guards and run a way too narrow a tyre for the rim size.
18x10 +20
cool...thanks grant.
mate has a set of eurolines ..18*9 and 18*10 ..both with +35 offset...i'll try them for fit this weekend....oh and tyres are 235 at the rear too...really stretchhhhhed
Running Advanti Racing 'Karla" wheels:
Wheels: 19x8 +35
Tyres: 245/35 R19 Hankook K104
They are being replaced (due to a fault) with Enkei RP03 model which should fill the guards a little more, I think.
    • I figured out what’s wrong. It’s something to do with the high beam wire short circuiting. When I measure the continuity with a multimeter on the headlight socket connector it gives me a continuous beeping noise when I put it on the ground socket and also on the high beam socket.  On the passenger side of the car (working side), it’s only beeping when the probe is on the ground socket. Which makes sense.  So that means it has something to do with the high beam power supply for the drivers side. How do I trace that? Is it the turn signal lever malfunctioning? The one that also controls the high beam and low beams.
    • Hey lads just finished tidying up a gtr a bought. Originally from Sydney now living in New Zealand
    • Hi Guys, Looking for this piece if anyone can help out.   https://tfaspeed.com/products/nissan-skyline-r33-gtr-rear-trunk-finsher-panel
    • How did you go with your problem? End up fixing it. Have a y34 aswell vq30det
    • But if I smoke test 5th cylinder it’s all ok, no leaks  when I try with 2nd it’s leaking exhaust and intake, it doesn’t come from oil dip stick.    so maybe when car was running poorly, rich or sth. Spark plugs were black and covered in charcoal or sth lookalike. could potential contamination make valves not seal properly? is there also a possibility that rb’s don’t have equal performing cooling passages  meaning back of the engine will be hotter than front. Can this cause improper wear if engine was running under load for short time? Or carbon build up could just burnt from 4-6 and is still on 1-3?   I out of my head like really. Timing is as manual crank-exhaust 47, exhaust-intake 38 at this point I thinking about give it a try and make another 500-1000km and check if anything change, if not I will most likely disassemble engine head /or whole engine and send it back to rebuild. It’s killing me
