Post Your Wheels/tire Size And Specs
yokotas13
 Share
Ok, i figured other forums i frequent have them as well
please post as many specs of your wheels as possible
width and offsets being the MOST important
Picture from the side straight on, and one from the front straight on (to see if they stick out, or sink in for fitment wise)
ill start
Stock M35 wheels.
15mm spacers front and rear to clear GTR brakes
225/50/17 tires
17x7 id imagine is waht it looks like
Work euroline
18x9 -5
18x0 +20
235/40/18
above is with stock fenders
below is with midified fenders
Work Emotion XD9
18x9 +20 all around +20mm spacer on the front
225/40/18
please contribute
  • Replies 67
Grant you need to take a more direct side on shot of the emotions so we can get a better look of them on the car!
I will add a post tomorrow of the 2 sets of wheels ive had and sizes etc...
17 x 9 - Standard R33GTR wheels with 245/40/17's
Pictures are at 340 mm front and 330 mm rear, which was too low. It's now at 355 mm front and 350 mm rear, much better ride and handling.
:D cheers :(
  • 4 weeks later...
18x10 +20
dont get a 10 in the rear unless you get at LEAST a +10
but hten you will haev to do an agressive roll and pull in the rear.
anything less will hit your coilover.
18x10 +20
Your using 235's on 10 inch rims as per per your first post?
They would look mega stretched?
A "normal" person would use a smaller width rim and run the correct width tyre for comfort, looks, handling and safety
am i normal?
I use a 225/40 on a 9 inch wide and a 235/40 on a 10 inch wide
its about clearance, the stretch in the sidewall allows you to run a wider/lower offset without fear of rubbing so when the camber changes in a turn, it acts like a circle and not a square like a normal tire
am i normal?
NO :thumbsup:
That's why you should explain or clairfy when posting esp when people are asking a question about a topic they do not know anything about. Otherwise someone is going go and buy a set of wheels too wide or the wrong offset and have to beat the shit out of the rear guards and run a way too narrow a tyre for the rim size.
it is not too narrow
a 215/40 or a 205 is narrow
the sizes that i have on are a good medium.
adn are proven to be reliable on a rim of that width
18x10 +20
cool...thanks grant.
mate has a set of eurolines ..18*9 and 18*10 ..both with +35 offset...i'll try them for fit this weekend....oh and tyres are 235 at the rear too...really stretchhhhhed
Running Advanti Racing 'Karla" wheels:
Wheels: 19x8 +35
Tyres: 245/35 R19 Hankook K104
They are being replaced (due to a fault) with Enkei RP03 model which should fill the guards a little more, I think.
R34 GTR 18x9 +30
245/40/18 or could be 245/35/18
My car looks like these 2 once the front gets painted. Mine is silver
that looks amazing :thumbsup::D
Edited by Brycey
Brycey, the site you hotlinked from does not allow it, look at your last pic......... not very appropriate............ can you fix please?
 Share
    • Hi all,   was wondering what are the best add on side skirts for the n1 spats. I have a front lip by top secret right now which I want to even out in height.    if nothing is good out there might just get a top secret carbon hood.    added a recent photo of my engine bay for viewing pleasure. Coming along slowly just taking a while in Hong Kong to get all the parts. Next up is a titanium custom intake for my hks turbos.   thanks
    • I don't know of anything specialist about the Stagea and pulling it's CVs, but the ones I've worked on, are all damn easy. Nothing "hard" at all, not even anything really technical or needing any crazy knowledge or precision. Have a Google as you straight up might be able to buy decent replacement CVs/axles for the Stagea.
    • I didn't realise you used to work at a place that does tuning! I know while I'm putting the Subaru back together it'll need a remap, but I'm pondering how easy it'd be to do logging at a track day. I've got an Innovative LM-1, and am pondering if I get a new O2 for it, or what a decent Wideband (standalone) sensor and controller is worth that I can log (And either ECUFlash or ECUEdit might support). I was searching for hiring a dyno for DIY tuning but looks like only 2WD dynos can be hired at the moment and I need 4WD
    • Dropped her down and rolled her out onto the driveway for a much needed wash.  Jacked her back up this morning and managed to get another 1L of oil into the trans and bolted the tailshaft back in.  Replaced the FP sensor last week and checked for any other leaks. All looks good so far. Just need to wait for my mate to come over now and get it started.
    • Looked at ConceptZ HKS exhaust i just find $1000 shipping sounds crazy. and that was USD so $4400+ after AUD conversion thats the exhaust and shipping. just seems crazy is there anyone else in Aus that sells any of these exhausts?what about these will they fit they say up to 2016 though mines a 2020 just wondering if they will fit?
