  • Replies 67
diameter doenst ever matter reall as long as you get the correct tire to make it near rolling diameter
Ive seen 20s that are only an inch or two taller overall
Its not like any of yuo slam your cars like i do and have ot worry about fender to tire clearance (FOr the most part, i know some do)
The only thing 80% of the people that ask need to worry about is width and offset
mate your obviously not from australia as we have 100mm ground clearance rules here. no offence mate but i have owned bagged minni trucks which dragged rails and you still need wheel clearance. or you become good friends with the pannel beaters real quick.stageas are mad roll around cars and not ment to drag arse its all for the looks and style why your rollin.
yeah, i slam the shit out of my stag
i dunno about you
EVERY car should be slammed in my eyes
y?
fair enough it looks good but sometimes you need practicality.
gaurd clearence has a lot to do with wheel selection. i live in a town with probly the worst roads in australia and iam telling you go over a bump in a "slamed car" and bang you just f#%ked your gaurd and your tyre and if you made bad tyre choice, bye bye expensive hubcap. wise up smart ar$e.
you need good tyre rim and suspention choice to drive around or you will be paying and looking like a fool.
yeh that is what i think. and maybe should hang out on a mini truck sight that is where people go to dribble shit. they do stuff first then try figure out they f####ed up so then they just run stock rims . yeh low is good for shows but my stage is a daily drive car and cops in australia dont need another reason to give you some arse action. and the roads i agree they could not get any worse.
and dude you no by pulling your drive shalfts out. that they are the only thing holding your front wheel bearings together.as they dont have a stub axle to bolt them in with . ganna look sweet driving down the road and your wheel overtakes you right after it rips your guards off real sick. any other bright ideas does any one listen to that guy .
i think he is trying to say that he has pulled out the front tailshaft.not the front shafts to the wheels.i mean come on guys you dont have to call him names for voicing his opinion here.i was on the understanding that if we agree with what someone tells us we might try it if not well what the hey at least the information was offered.i dont know fark all compared to some of the people here but if i thaught something will work id say so and not expect people to put me down if im wrong. just my 2 cents worth. well maybee 4 cents.................regards mike ................
I have always wanted a set of Nismo LM1s and have finally found some with 265 18 35 tyres. They are off an r33 gtr and have a r33 standard offset . I have flared MASA wings on the front with 235s at present which are nowhere near the outside of the wings
I have another stagea with 255s on the rear with a small spacer. so it looks like the wheels could fit
Anyone know the std offset of a R33 and what I would need to do to make the LM1s fit I am prepared to roll the rear arches if neede be.
R33 GTR wheels fit (SK has them on his S1), not sure on the 265 tyres as the 33GTR's are close and fill the guards well, the tyres might just tip the fitment over the edge.
Thanks
My main worry was the offset bring wrong. As I said front wings are MASA and flared out by about 35mm .
Rears may need 'rolling' but 255s fit so it should be ok if the offset is Ok .
I will let you know how they go on ( hopefully)
a mate is offereing some stock wheels off an is200 real cheap - stock 16 x (whatever is normal) 225/50/16's stagea wheel size but with a +45 offset. Any problem with this? - only thing i can guess is rubbing on the guards at full lock? - car is not lowered as yet but as soon as i have tax back i will be purchasing the whiteline bilstein kit.
Edited by captinsane
Assuming the stud pattern is the same (which I think would be the case), the problem youll have is with clearance if your offset is too high.
Trial fit the rims to check if they clear the suspension arms and brakes etc :)
+1
Assuming the width stays the same, the higher the offset (higher number after +), the further it is going to sit into the guard. Most likely I'd imagine that you'll be fouling on some suspension components..
Are these the rims your meaning? This is my daily rs4, i think the stickers are still inside the rims, i could check if the offset is written on them if you like?
+1
and the only way to solve that is with spacers - which are illegal?
cheers - thnks
    • 200 cell cat will probably help. Do you have room to tee off a Helmholtz resonator anywhere along the exhaust? These can do wonders for drones, with a little experimentation with regards to length.
    • The car revs up through the gears much better/faster now, and fuel consumption doesn't really seem to have be affected either on a Hwy cruise, which wasn't expected  The FAB9 intake manifold has been problematic sourcing though, I've contacted Plasmaman to ask about their intake, which you can get different runner lengths spec'd, and, their different options for throttle bodies  The only real physical drawback with the Plasmaman intake is how to connect it to my current OEM style airbox, as FAB9 make a OEM style back half of the airbox to suit the larger diameter throttle body, and all that is required is a 30°bend silicone pipe to mate the throttle body to the airbox Car also goes in for some exhaust work in a week or so to fit the biggest resonator they can fit clearance wise in the front pipe to help remove some of the drone, there isn't alot of realestate under there, a rough guesstimation is it will only be about 3-400mm long and maybe 90-100mm diameter, and with a 60mm exhaust that doesn't leave alot of space for the internal volume of the resonator to do its thing I'm thinking I may need to bin the "high flow" 100 cell cat for something a bit more substantial, yeah, and restrictive, like a 200-400 cell, to help, but, I have ample room for a really large bodied cat to replace the current one which has around a 4" diameter body I may look around in the recycling bins and see if I can find a massive newish cat that was "replaced" with some new full exhaust system that the local exhaust shop in Western Sydney is doing
    • Hahah look at that smile 😂 Just like those ones on IG where they compare the husband in family photos vs husband going fishing lol. I don't think I'll participate this time, clutch isn't in and also the last time I went there were too many numpties on the cruise sessions. Nearly caused a few accidents holding up people and a few guys initiating massive kerb to kerb drifts with heaps of cars right behind them. Not to mention, there were guys on the track session using it as a power cruise session.
    • Is there an actual website thingie for peoples who don't have Facebooks? Cheers
