HEY Guys I just need some help, Iam looking on da maket for a exhaust system
Dont no wat i should get a normal 3 1/2 inc exhaust from turbo back
or
A straight pipe 3inc like most drift cars have (nice and loud).
Wat i need help on is wat iz beta. and wat iz beta for power. and how r they diffent.
THANX FOR UR HELP.
https://www.sau.com.au/forums/topic/164937-watz-iz-a-beta-exhaust/
faaarrrkkk, well a 3 inch or a 3.5 inch are both gonna be good and it comes down to price. Go with what you can afford
I doubt youll reach the limit of the 3 inch but in extreme applications the 3.5 inch is obviously gonna be better flowing than a similarly designed 3 inch exhaust
Michael...only Joking with you.......
The best exhaust are the ones that have the following.
Cat...Resinator...Muffler...Hot dog.......all in that order.
So if you want to get one custom make sure they are all 3 INCH.
Stainless will give it a different note than mild steel.
I will be fitting a muffler in mine soon...
The muffler you should get is the one that is straight through and not bent inside like a snake....but acts as a
larger resinator.
If you have money...just buy a Japanese one for your car..all the good types will have res.muff and dog
Good luck
Tekin, i dunno how serious you are with that last post but geez you float some terrible information around
Why would a good flowing exhaust have 4 lots of restriction in it? (Cat, res, hot dog, muff)
Rav: Youd want something with a Catalytic converter and a rear muffler/cannon (if you like sound)
If you dont like sound as much go for an exhaust with a cat, middle resonator and a rear muffler/cannon.
I have noticed all the brand named ones.....go by what I have stated...........(Cat,res,muff,hot dog...in that order)
Some even have a 4 Inch hot dog out at the tip.....which looks good.
So if most of the exhausts that cost $2K plus have these then they have done some serious research and have proven it not to be restrictive.
They are not restricting flow but more////making it less noisy...but still sounding great at higher revs.
No probs Rav
a custom job will be cheaper and they will makes the pipes run closer to the chassis if you ask them to make it for you compared to an off the shelf Jap exhaust
ask the vic guys...there will be heaps of good places to go
Ok now for da next question Lol wher iz a good and cheap place to get exhausts from?
and iam from melbourne so if sum one can help thanxxx alottt.
Depends on where you are. There is a good exhaust centre on barrys road...broadmeadows....and also a good exhaust centre on settlement road Bundoora........As for the other side of town...need to go through the Yellow pages.directory....
All places are the same...just know what you want and they can price you and fit.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
