  • Replies 150
yeah.. was pretty hard hit.
i was sitting on hamilton rd, waiting to turn right into ocean rd, then i hear screaching brakes and see a white commodore sliding towards me, no time to move, bang!
witness said he overtook her a bout 500metres back doing 100+ almost hitting oncoming cars, then saw him fly into my back end at ~80km/h....
fark that
now you know why they call them crumple zones
same with my car when front on - the bonnet just concertinaed
whats the go with insurance????
i almost had that the other day with my excel
you know albany h'way and nicholson road intersection - i was turning onto nicholson right (ie coming from carasoul), and traffic ala sudden stopped cause of lights, chick on P plates screeched to a halt about 10cm away from me - not once, but twice (traffic surged forward, then stopped again, and she nearly hit me twice)
mind you, i wouldnt have really minded, my rear bumper is crap, and side panels are slightly dinged
insurance would have been a bitch to follow up tho
Edited by 342Four
I'm fine... Mitchy was bringing me lunch :) happened at the end of my street at work :P
The guy took off straight after details were exchanged, my bet is he had been drinking!!
All Mitchy's hard work and time in that darn motor is now down the drain :)
for the purpose of this thread... that was kylie posting
hmmm
kylie being mitchy, and mitchy being kylie
glad your mitchy's okay :)
have fun with the insurance follow up - can get painful (thank f**k mine was simple)
all that hard work into the motor and i bet your f**king glad it hit the back end (oz spec r31 receiver car ftw :P )
Edited by 342Four
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
