  • Replies 150
i took a hit in the rear in my r33 and it was written off and was no where near as bad as this. i know the feeling mate, hard luck indeed.
see if u can buy the wreck back off the insurance company then strip it down :-)
R33 GTR upgrade now?
Edited by _8OO5TED_
Geez that sux Mitchy...glad you are ok. Looks like a real hard hit. I got hit in the rear (same spot in the rear) in my clubsport and the damage wasn't anywhere near that!!! Next car????
hey...you can buy mine >_< hehehe
Its a very sad site at home today. When I opened the blinds to let the sun in from the kitchen, there she was, all twisted and crumpled.
Mitchy is a little overwhelmed with what happened and isn't sure how he feels, whether it be sad/angry etc... I feel very sad, You come accustomed to someones car being a little bit of them....and its a bit of mitchy out there all bent and twisted. :(
What I don't like and find very insensitive are those people pm'ing him already asking for parts. >_<
IF he decides to buy back the car from the insurance co, all parts will be in the for sale thread.. Since this only happened yesterday, I doubt that that is going to happen anytime soon...so grow some patience and some decorum... www.dictionary.com for those that haven't seen that word before!!
There I've said my piece >_<
Thanks,
Kylie
Glad to hear you're ok Mitchy. Sorry about the car >_<
Kylie - I agree. When my 180sx got written off people started asking for parts that day. The same thing happenned to Dan with his GTR. Its so rude.... the last thing you're thinking of is pulling parts off your baby to sell.
So what happens in this situation? Did you manage to drive the car back to your house or did the towie tow it back.
I have always tried to figure out how towies work as i think they get paid extra $$$$ for towing it to panel beaters and I was under the impression that if the police come it has to go straight to a panel beater? can anyone confirm that?
If it is at your house and no one has taken records of whats damaged etc then does anyone know how far you can go in removing parts?
I dont want any parts as SLY is lovely just the way she is, however should unfortunately this happen to any of us this could be of interest to us all to make a somewhat smarter move out of an unfortunate incident.
Mitchy, Kylie - My condolences to both of you.
    • The cross sectional area of a circular hole scales with the square of diameter. So a 2mm diameter hole is 4x the area of a 1mm hole. Not double. The 1.7mm hole is nearly 3x the area of a 1mm hole. You do not need restrictors at both ends of the oil supply line. If you have new, additional restrictors at the turbo end, that you did not have before, then you do not need a restrictor at the inlet end.
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
