i don't think you would want your core powder coated - maybe the pipes, but that stuff is a bit thick. much thicker than spray paint or anodizing that's for sure. powder coat is tough for a reason.
i had mine painted by a radiator shop for $20 bucks. Looks fine to me although it's a little bit glossier than i was expecting.
I've seen intercooler cores powder-coated on twin turbo LS1 motors, running well over 240rwkw without an issue!
Some of them running 11sec passes at the track, and also being street driven, daily.
Dont think it would be an issue! It is quiet thick, but when exposed to air they to cool quiet well..
Edited by abu
That doesn't sound like much power from a twin turbo LS1. Maybe it is a problem?
Anyway, I asked this question a while ago. http://www.skylinesaustralia.com/forums/in...c=54462&hl=
Hehe was a run in tune.
Car ended up doing a flat 11sec pass with a slipping clutch.
Will check out the link!
Thanks
FORD XR6 turbo come out of factory with black powder coated FMIC.
There stock intercoolers are fairly small, but are good to flow between 270 -300rwkw, and has been proven by many!
APS also powder coat most of there intercooler black, along with many other workshops with big HP cars.
Edited by abu
re-worked my engine bay in the beemer..
i did my pipes in 2pak black.. been running like this for about 2 months now without any signs of the paint going bad.
cost me 60bucks for paint+hardener and still some left over :)
powdercoating can be applied as thin or as thick (up to about 3mm) as you like.
the thinner the coating the rougher the finish it, but on a satin finished intercooler you could get away with a lighter coating.
    • Neo IACVs have water plumbed into/out of them to provide the heat to close the AAC. I am also unsure about vanilla 25s, but maybe the extra plumbing on that is water.
    • Those injectors are 100% Nismo 555.
    • I found this in another thread, now I'm second guessing myself and thinking there was a vac line from near the throttle body to up to the IACV too.   https://saufiles.s3.ap-southeast-2.amazonaws.com/post-59171-1251456228_thumb.jpg
    • Hey Duncan,  What ports are on the plenum itself? The new part welded up for the AAC looks like it's a T Piece to go upto brake master, and the other side into the plenum to feed air in. Brake master vac line on R33 from memory has a one way valve inside of it I believe (middle of pipe). I'll check mine tonight when I get home, I think that pipe is still sitting on my R33. You're also testing my memory, but I don't believe the R33 has a cold start valve, it just has the IACV doesn't it? That second smaller port on the IACV itself from factory, goes down and under the inlet manifold, but I can't remember what it plumbs to.
    • I once hit my knee on an exhaust on my sisters Suzuki Sierra after she drove it her *normal* way. My knee looked like porridge for weeks. Bec and my daughters never go near this car. I can see one of my dogs losing an ear though. 🤔
