  • Replies 74
well bkc.
here are a few tips for you.
cams will generally reduce your idle quality (lumpy idle, and you will most likely have to raise it to 1000 or even 1100 rpm to get it stable)
cams will generally reduce your fuel economy
cams will generally increase your emissions
now, please note I said 'generally' not always. mild cams will not have a marked effect.
by far the most popular choice in aus at the moment for RB26 running between 400 and 600hp would be Tomei Poncams Type B (260/260, 9.15/9.15).
If you are running around 600hp they would be a good, safe choice.
well bkc.
1- stock fuel pump & injectours for 600 hp to the wheel ??
this same duration & lift cam for the power inlet ,exhaust are you mean that ?.
but : and if I want the response Difference is better ?
I mean if fit it up grade the cam shaft for the GTR34 ,
what is the better same ( duration & lift)) for the power or
difference(duration & lift )) ?
The same question if I want response ?
what is your opinions ?
note: I don't mean mark !!
Where are the brave young men where they went? :):P:)
note: I don't mean mark !! :sick:>_<
i think something similar as to what im about to say was said earlier by 'Beer Baron'
Tomei list their higher end Poncam (type B) with the same duration for both the inlet (260) and exhaust (260) cams
Whereas, their base level Poncam (type A) with different duration for the inlet (260) and exhaust (256) which supposedly gives more mid range punch, thus providing more response.
The better one is what YOU want. I think since youre chasing that magical 650 rwhp mark, then youll need to rev and make peak power. HKS list there stage 2 cams as 272 degrees duration for both the inlet and exhaust with some 10.2mm of lift. I think you need to focus less on the differences in duration and more on whether you want 'stage 1' or 'stage 2' cams and then pick one.
thanks
thanks
Tank you for your reply
I can get 600hp to the wheel,, change up grade fuel pump intank ? & 650cc injectours ,,fuel reglator,, cam
shaft Tomei 260,,915,,X 2 i need know metal heade gaskit & turbos ?
what is opinion ?
If you want the mines R34 gtr it has HKS 2530 turbos.
You don't need a new fuel pump. The stock one is fine. But if you have to spend money so you can have a nice long list of aftermarket parts to show to your woman or sheep or whatever then go the Tomei in tank pump.
You don't even need after market cams. Some of the fastest low mount cars down here are running on stock cams with either garret 2860-5's or 2530 turbos and are all making around your 600-650HP. Some of the cars that have put cams in are now going back to stock cams. I had the Tomei 260-9.15's and have just changed back to stock cams on my R34 GTR.
Thank you very much man :mad:
are you sure do you say ?
but I don't know garret 2860-5's turbos you can give me site ?
thank you thank you thank you :(
MINE's crazy response !!:rofl: & good power !
note: MIN's stock metal head gaskit & how many full boost ?
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
