Im getting a zorst this weekend and need to drive it to mechanics. Question is, do I need a large wagon to drive it to the mechanics or can my Skyline coupe do it? Will the exahust be split into 3 pipes or will it be one whole assembly?
Its from Just Jap JJR zorst.
Cheers
Edited by CCCP
https://www.sau.com.au/forums/topic/165032-q-about-exhaust/
it depends on whether ur goin with a turbo back zorst or catback...... cat back it will be split into 2 pipes and turbo back will be 3 pipes.......... but ur coupe should be able to handle it....... does ur back seat have that bit in the middle of the back seat that folds down to open thru to the boot??? if so u will be bale to run the pipes thru there from the boot into the backseat... thats what i did when i changed the zorst on my 34 4 door....... i brought the original zorst home with me in the skyline.... lemme know how it goes
https://www.sau.com.au/forums/topic/165032-q-about-exhaust/#findComment-3059529
Its the trubo back.
Ive been todl by JJR it should fit into my R33.
Im not sure if the seat in the back comes forward i dont think it does... any R33 owners know for sure?
https://www.sau.com.au/forums/topic/165032-q-about-exhaust/#findComment-3059653
think about where the battery is in an r33 coupe :D Its not going from boot to back seat
What i have organised with my exhaust when its delivered is that the company will deliver the exhaust straight to the mechanics so i can just drive there, get it installed then drive away :D
https://www.sau.com.au/forums/topic/165032-q-about-exhaust/#findComment-3060243
think about where the battery is in an r33 coupe :P Its not going from boot to back seat
What i have organised with my exhaust when its delivered is that the company will deliver the exhaust straight to the mechanics so i can just drive there, get it installed then drive away :P
I cant do the same seeing as the mechanic who will be fitting my exhaust does not have his own workshop and will be using his friend's.
Edited by CCCP
https://www.sau.com.au/forums/topic/165032-q-about-exhaust/#findComment-3060511
it will fit, just take it out of the box, lay your passanger seat as far back as it will go and put it in, just put some cloth around the end near you dash to avoid scratches.
do the same with the old exhaust it should fit two, but you might want to put it into a old sheet or something first
https://www.sau.com.au/forums/topic/165032-q-about-exhaust/#findComment-3067857
Thanks, that was my innitial idea... it looks like there is a bit of space there.
https://www.sau.com.au/forums/topic/165032-q-about-exhaust/#findComment-3068270
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
