  • Replies 86
Posted Images
On call 24/7 Xmas & NYE - Sunshine Coast
On-screen credit
Socially responsible project
It is going to be tough with long hours and being on call 24/7, but our project is worthwhile.
Young people are continuing to die at an alarming rate on our roads. How many will die this Xmas?
You could help to save a life, and gain experience and production skills.
Payment is $1,000 - $2,000 for the ten days depending on experience. If you have your own equipment (camera), we can negotiate for its use.
We can provide basic accommodation and a guarantee that you will have a good team to work with.
We are looking for a reliable committed person with some experience in video camera work and possibly post-production. You will need to submit some show-case material.
We are based in Maroochydore on the Sunshine Coast Queensland.
Loraine McElligott
Westwood Enterprises (Qld) PL
BH (07) 5443-4500
FAX (07) 5443-3343
oh god.. these guys really are on a misguided crusade aren't they..
They've got another ad going too..
Video Editor - Sunshine Coast
Roadside Watch is an internet-based service designed to assist in reducing the road toll. Based on the Sunshine Coast.
Contract video editor will require their own editing software and computer.
Separately, a short dramatic promo also requires editing.
Opportunity for further work in editing / video production down the track.
Project must be completed by Easter Thursday.
Loraine McElligott
Roadside Watch
PO Box 111
Cottn Tree 4558
Email: Please click the 'Apply Now' button below.
I might give them a call and let them know prevention is better than stalking. Maybe they should train drivers... Make a driver training facility up there...
But yeah, thats gold.
"hoon removal kit" http://www.roadsidewatch.com/use/server.php?page_id=4208
These people really aren't too intelligent are they?
# McElligott L
# 86 Beach Pde Maroochydore 4558
# (07) 5443 3343
btw: well if they're going to claim 'public interest' for filming people without their consent, so is the above..
in the "roadside watch policy" part
they liken hoons to gunmen wandering the streets lol oh my god, wtf are these ppl doing.
QUOTE
5. Report it. If you saw a madman in the street with a gun, you would not hesitate to call the Police. If you see a madman in a car endangering the lives of others, take a video and send it to us. We will forward it onto the Police. Don’t let someone kill the ones that you love, just because no one bothered to slow them down.
Edited by 85URK
# McElligott L
# (07) 5443 3343
Is this the ring leaders addy?
a removal kit...
i was just going to say this setup would be sweet to record some in-car footage at a track day... but $1500!!! fark that.
Technical Specifications
Electrical
Voltage 8 to 40 VDC (12 VDC Nominal)
Power up to 1 W (not including cameras)
Battery Pack 9.0 VDC 700 mAH Rechargeable NiCad
Video
Inputs 4 Female RCA Connecters
Outputs 1 Female RCA Connecter (for setup and live monitor)
Type NTSC Composite Video
Image Resolution up to 360 x 256
Frames per Second up to 10
Recording
Triggers 3 NH and 3 NL inputs (3 negative and 3 positive inputs)
Medium up to 1 Gigabyte Secure Digital (SD Card)
Pre-Event up to 2 minutes (varies +- based on resolution and frame rate)
Total Duration varies based on resolution, frame rate, and SD Card size
Physical
Dimensions 6.1 x 4.2 x 1.5 Inches (Main Unit), 2 x 1.0 x 0.5 Inches SD
Weight 1 lb.
Operating Temp. -40 to 70 C (-40 to 160 F)
Connections +12 VDC, Ground, Ignition, Power to Cameras (x4),
Camera Inputs (x4), Video Output, SD Card Pod, Triggers
EDIT: actually they're pretty crap cameras
QUOTE
I gotta say, Id also report some freaky barstard out the front of my house with a camera sitting in their car for 3hours!
    • If it's reading full rich prior to a misfire that gives one directional hint, if it's already reading lean, etc. If it's reading pretty cleanly stoichiometric then suddenly drops out from a misfire that suggests it's not air mass estimation that's the problem. Could be ignition, could be something more subtle. Could be the CAS has decided to start dropping out at random or the drive pin is worn leading to excessive lash and trigger errors. LTFT can tell you the same but it's slower to react and if this is a recent issue it might not have stabilized. STFT stuck in one direction vs fluctuating back and forth can be used instead but I like to read O2 voltages anyways and interpret directly. If the O2 voltages make no sense in general or are super slow to react it could also be a failing O2 sensor. There's no real error correction for failing O2 sensors in these cars.
    • How will O2 sensor voltages help to identify it when it is sputtering?
    • What do LTFTs look like? What do MAF voltages look like? O2 sensor voltages/AFRs? Knowing O2 voltages especially when it sputters would help a lot.
    • Isn't this what everyone immediately sees in their mind's eye when someone gives them a total width number and an offset?
    • It won't be this - not while it's driving, anyway.
