Quick question guys,
How do you guys get a wire from the engine bay into the cabin on the passenger side? I have to get the wiring loom for my EBC into the cabin...i have removed the grommet where the loom from the engine goes to the ecu but i can't find a way through into the cabin...car is a r32 gtst...can someone help me out? cheers...
Edited by limpus
I tried that and a coat hanger, nothing would work for me so i ended up just drilling a few holes in the firewall and lining them to come out just above the break pedal mounting bracket (where the metal isn't reinforced and theres no carpet to get in the way
find a grommet and chuck it through with the shit going through that...
coat hangers are rather handy :P chuck that through first, tie your wire on the end of that then pull it through...
thanks for the reply fellas...i have tried the coat hanger method but it can't get thru...i would ideally like to have it on the passenger side as that is where the turbo sits...anyone have any other ideas? Cheers....
drill? some people dont like to drill into the body of a car... but there are holes all over the damn place... as long as it looks near IF you can see it, then its not a big deal...
I used the big grommet on the drivers side for my amp power and ebc wires. It comes out high and to the right of the gas pedal. I just taped the cabling to the end of a screwdriver and pushed it through.
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
