Hi guys
anyone got any idea's what an R34 Neo engine loom would be worth that has had all the engine plugs removed? So all thats left is the plugs that go inside the car, and the plugs from the engine wiring such as alternator/ trans etc?
Basically the engine was used in a conversion and the plugs that were needed taken, and thats all thats left.
thanks
Neil
https://www.sau.com.au/forums/topic/165051-r34-neo-wiring-loom/
Hi guys
thanks
Neil
its pretty much scrap dude
