u'll probably find that its not the input shaft bearing but actually the counter-shaft centre bearing. did u get bits of bearing race stuck to your drain plug?? been through this 3 times now with 3 different boxes. got it down to 45min changing the box lol. ended up getting heavy duty bearings from CBC bearings. let me know if u want someone to replace the bearings for u i can get it done pretty cheap with the heavy duty bearings.
I also have an RB20det box that is on its way out. I bought it in so called "excellent condition" I got shafted! as soon as it went in i could tell it was not right.
It makes a clutter type noise in 1st 2nd and sometimes 3rd epically changing down gears under compression braking. I have rung a few places and got really vague quotes for "about 1200 mate..."
I would like to get it rebuilt but what sort of price is reasonable? and exactly what gets replaced?
Cheers
$1200 is a reasonable price for an un-inspected box.
They will generally replace all the bearings. Some workshops won't do all of them...just the ones that are worn.
They will replace any other parts which may be worn. For any of your regular gearbox shops they will charge you around $1200 for a basic rebuild which will cover you for labour, bearings and most of the time one or two synchro rings and that's about it. Any more damage inside and the bill goes up most often.
I do the RB25 and RB26 boxes starting from $800 for bearings, seals and labour to strip/reassemble. This doesn't include any synchros or gears. I generally stay away from rebuilding RB20 boxes as they are much weaker than their counterparts. I recommend the cryo treatment if you want to stay with the 20 box as it will increase it's strength by around 2-3 times.
Thanks for the reply, that was exactly what I needed to know ;) Cheers!
3lit3 - would u happen to know what the (aftermarket) part numbers are for bearings for a rb25 box? I want to slap a set of bearings in mine, and was wondering cost of bearings from cbc or the like...
i used to work in a nissan dealership and we used to just take the bearings down to CBC and they match em up on the spot.
ps we never charged for genuine parts, so it wasnt monkey business.
    • Haha luckily we don't have emissions, inspections, or any laws against power adders here. They only thing they somewhat keep an eye out for are ridiculously loud exhausts.
    • Just wanted to pop in an update on my setup. The CD swap has been great, I love the mazworks housing for the overall simplicity. I ended up sealing my trans tunnel with a thin sheet of aluminum reused some of the holes on the trans tunnel, and laid some window sealing EPS foam around the edges. Works great, really quieted things down and sealed up the car.  As for the power comment. Right now I am also running about 650whp. with the way the bell housing is attached to the face of the transmission I have zero doubts it would be fine, mainly because the input shaft and main shaft bearings are seated into the bell housing adapter. This means the load is NOT on the bolts to maintain the power, rather into he casing of the bell housing; Yes the bolts are doing some work there, but with both shafts locked in zero worries.  End of the day, the Mazworks solution is the easiest and safest. no need to take your trans to a shop to get milled perfectly, it fits with minimal clearancing, and you can use all your existing clutch and flywheel.  Driving wise the CD has been great compared to the big box, I'll probably swap my final drive at some point. The serial 9 shifter is gooooood, my only qualm is how tight it is, it takes a fair bit to get use to, 5th and 6th are a bit eh/hard to find at times, but maybe I need re-adjusting, and I think my clutch master is very tired and needs a rebuild.
    • If you are keen, have a look at my build thread. Car is for sale for the right money or straight swap for a F80 M3 LCI.
    • Welcome mate.  No point in over thinking it, buying any one of those cars you mentioned is not a smart or logical choice with the availability of many "better" (re price to performance) cars available to you.  The heart wants what the heart wants, buy whatever it leads you too.
    • Hey everyone! Im so grateful to be apart of this community and ill do my best to be apart of this. Firstly, i'm not disclosing my real name due to in real life circumstances surrounding my privacy and public image (sorry lol) Secondly, The only thing personal I am willing to share is that I'm from Sydney and a descendant of one of Sydneys largest mortgage firms. I got gifted my first ever car, a 2022 Porsche Cayenne and I love it to death. Ive been driving it for about 5 or 6 months now and honestly Im so grateful for my parents for gifting me this vehicle. However recently I've been working my ass off to afford my second car (which I need help deciding soooooo community help me out please?). Once decided, im planning to try modify it myself. Recent I've been thinking about getting a Skyline, particularly a 25GT or GT-V, yes I know overrated as hell, but I'm also considering a Chaser which I recently came to love. However my dream is to one day own a 180SX (So hard to find clean versions and im not really into importing).  Lastly before I send this off, I want to apologize if I sound tacky or pretentious. I try not to and want to genuinely learn from everyone and anyone. (Im no expert in this area) Thanks for reading!
