Bov
Adz2332
 Share
The only place ive seen that has an aftermarket metal intake pipe (metal is meant to make the flutter echo and sound better) is on the nengun website Apexi have a full intake kit for the r33gtst and possibly 32 but im not to sure.
Only prob is its like $300 but it does include everything you need and the pod filter too
  • Replies 46
I paid half that for just the pipe w/ clamps & quality silicone hoses - best I've seen (5ply). :P
For a similar custom pipe alone have been quoted the $200mark in the past.
i got mine from Shy180 on the forums too.
Hey Cubes, what type of metal did u use to block the bov? and what did u do to block the vac line?
im considering doing this after what ive read here :P
Edited by Sambo33
While on the bov question. My car I just bought has 2 bov's in place :P as seen below:
I want to remove the aftermarket one, so I bought a new stock cooler return pipe (black pipe). I was going to replace it today, but then noticed that the vaccum line has be re-routed to the aftermarket bov, and the stock bov has the pipe where the vaccum attached removed/blocked with a screw!!
SO, can I replace the cooler pipe to remove the aftermarket BOV and just block the hose from the manifold?
How does it affect the operation of the factory BOV if it doesn't have a vaccum/boost reference?
If you dont block this hose, does this not cause a boost/manifold leak?
Cheers for the help
Edited by Hotwire
You would want to use the stock bov if you dont have an aftermarket ecu of some sort because the stock ecu has been programmed to run with a plumb back bov so not having one will make your car run richer at certain times (ie gear changes) just run the vac source back to the stockie bov
and yes if you didnt block the boost/vac source it would cause a leek
Edited by /2on
Sambo33, it sounds so much better with the plate there :santa:. I'm going to get the intake pipe this week hopefully, otherwise might just pm shy180, how much did people on here pay for just that pipe usually?
I pm'd shy about the intake pipes about a month and a half ago and he said there out of stock and aren't getting anymore in :thumbsup: there is one guy in the for sale section selling one for $200 tho
Edited by /2on
Sambo33, it sounds so much better with the plate there :P. I'm going to get the intake pipe this week hopefully, otherwise might just pm shy180, how much did people on here pay for just that pipe usually?
yeah i blocked it off this morning, lots of chatter now! haha. i took it for a quick drive and everything works fine, no stalling ect. i couldnt really open up the throttle too much (being in the city and all) but i think it feels a bit more responsive than before.
i cant remember what i paid for the intake pipe, ill try and find out.
  • 1 month later...
instead of puting the plate inbetween the bov and intercooler piping.. isnt it easier just to disconnect the vacuum hose from the bov and plug it up... that way the bov never opens??
my mate done it on his... he loves flutter...
i prefer the stock clean wooossshhh
 Share
    • so finally had an event i was home for that didn't get rained off or otherwise cancelled to be able to actually drive the car, unfortunately was roll racing which isnt my favourite thing ever but had an awesome night with friends and testing the car out. obviously a huge difference in driving experience with the samsonas although still without flat foot upshifts the ratios are so much nicer and actually has boost into the next gear which was not something i always experienced with the stock gearbox. but of course absolutely loving the sound of the sidepipe and for its downfalls of ruining the car in ever other way it does sound awesome at the track.   had some weird issues where it would misfire in 2nd but fine in every other gear and at the end of the night at the end of the run would have no throttle until it decided it wanted to work, so will be looking into that before a proper track night coming up in just over a week to really see the changes in the car. Messenger_creation_C9B7F84E-0820-444B-A53D-9AD40F7DDC5B.mp4     received_870009858147161.mp4   Messenger_creation_046B1D12-ABA0-4B01-B78F-262559E64ADC.mp4  by the end of the night found that if i was nice and gentle on the throttle in 2nd it wouldnt misfire so was only fully throttle and loaded up in 2nd it would occur
    • I think I will try out Frenchy’s power steering kit. Looks like a better solution.
    • Useless lot aren't they? Releasing stuff on the market that doesn't do what it's supposed to do without you stuffing about with it and spacing out the spacer lol. FFS.
    • Similar experience with Ross pulley. Can't recommend.
    • Hey guys I’m putting my 180sx wiring loom back into my car and I’ve run the interior harness out I’ve noticed that on the passengers a pillar there seems to be a section of holes where zip ties would go as if to run a thin 4 wire harness to the roof I’ve searched through all of my stuff to try and find this harness but I can’t seem to find anything. I’m just wondering what the passengers side a pillar( on the windscreen) harness/wiring is actually for as I have already wired up my interior lights cheers
