I've got a '95 R33 GTS Type M with a big pipe, blitz BOV and a turbo timer, otherwise stock. Starts and idles fine when cold, as soon as it's warm it won't idle at all, stalls etc. I had a Honda Legend which started doing similar, and it turned out to be ignition leads- is this likely here?
It's only just been complied, and I think it sat for a fair while in Japan before being shipped. I've run one tank of PULP through it, half a tank with injector cleaner but with no improvement. Very occasionally it settles to idle, chugs a bit then idles properly, but not very often.
Edited by bikkies
https://www.sau.com.au/forums/topic/165075-idle-stalling/
its either your blitz bov, air flow meter, coilpacls, sparkies
cause atmospheric bov ruin your idle. chuck a stock bov back on and see how u go.
or try electric contact cleaner on ur afm. or swap and try someones u know is working.
coilpacks, check if u got any hairline cracks on them
sparkies check if they need replacing or ur using the wrong heat range.
hope that helps
https://www.sau.com.au/forums/topic/165075-idle-stalling/#findComment-3058159
hope that helps
Thanks for that- it ran the same (or worse) without the BOV, and with standard exhaust and airbox as I took it up to register with all stock gear fitted- we thought it might have been a tuning issue as it should have been tuned to suit the high flow air filter, big exhaust etc but made no dirfference. I'm thinking plugs and/or leads, or contaminated fuel from sitting. If it was a fuel issue though I'd expect it to be the same at startup. It also lugs and farts on the timer, but usually keeps running until switchoff. Confusing.
https://www.sau.com.au/forums/topic/165075-idle-stalling/#findComment-3058255
Hey mate.........
I am had some problems currently i am having THAT EXACT problem....... cold idle is fine! Its almost that choke is fine then...... starts to misfire and splutter when she warms....
http://www.skylinesaustralia.com/forums/in...howtopic=164545 thats my post........ there are some things u could try there..... but
out of interest i did CHANGE my ignitor loom
Edited by RipNGrip
https://www.sau.com.au/forums/topic/165075-idle-stalling/#findComment-3064655
i also have this problem.
i got a r33 gtst with a 3inch catback ex, FMIC, iridium plugs, K&N pannel filter, and a new o2 sensor. i thought it might be timming or the throttle position sensor.
any way im taking it to Mercury Motorsports to get a SAFCII installed and get my timming and tune done.
ill let u know how it goes once its done.
Aif
https://www.sau.com.au/forums/topic/165075-idle-stalling/#findComment-3068768
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
    • Put a hand on an injector and see if that's what the buzzing is. You might be triggering the injectors by moving off idle command.
    • Ah, should have been clearer. Currently has a flex sensor installed all good to go.    like u mentioned, I’ve only ever known the car on e85, I might hate 98, but I have to try it out first. Everyone says the -5 turbos get pretty laggy on 98 octane tho…
