they come standard on the Porsche and Mercs now which replace the P-zeros
Something interesting is they were started in 1871. Pirelli Group were started in 1872 and Goodyear was started in 1898 which makes conti the first according to the Wiki http://en.wikipedia.org/wiki/List_of_tire_companies
Edited by shaolin
The problem is Federal don't yet make (that I'm aware of) a genuine competition street tyre.
For what I call a comprimise tyre the Federal 595RS is a great tyre however. I've run on them for an Autocross day in an EVO 8MR and they were great. I use Falken Azien RT215's currently on my daily driver (MY03 WRX) and these tyres are nearly at and end and will look at replacing them with the Federals rather than the new RT615's. Along with the Toyo R1R's these are all classifed as street tyres in most competitions where true R Spec tyres bring class changes.
But the motorsport guys (including myself with my GT-R) are using genuine R comps.
Most of us that I know prefer the Bridgestone RE55's simply because the grip level is great and the cost is so much more reasonable than the Dunlops. I think a lot of us would use the Dunlop DJ02Z or even the new DJ03Z tyres but at around +$100 per corner more than the RE55's the costs can't be justified.
Tyres like the Advan A048, Michelin Pilot Sport Cups and Toyo R888's aren't providing the same grip levels as the Bridgestone or Dunlops and have the same price and wear levels so aren't regularly used either. But for the genuine motorsport guys you'll need a tyre with a UTQG of around 40-60 to get any real interest. I think from memory the 595RS are around 180.
Everything he said - he saved me typing it out :(
My favourite high-po street tyres are the Advan ad07
Neova's rock! Im sad that this is going to be my last set on teh street car, but f**ked if im paying for another set to come from Japan
When the RE01R's wear out on the front of the track car, I will have another think on what I will change to but compared to AD07's both have postitives and negatives which put them pretty much equal.
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
