Me and a mate were talking and came up with this as a possibility, think about it before you say "no way", informed replies are what we're after!
On to the idea.
Okay the reason you add a Z32 AFM is to reach the full 5V on the sensor slower than the stock AFM, the Z32 does it slower because it has a larger diameter pipe and therefore less air passing over the hotwire cooling it down.
So why not have a pipe bypassing the AFM from the airbox to anywhere before the turbo? The larger the pipe the higher percentage of air not going over the sensor, and fooling it in much the same way a boost controller affects the wastegate.
So anyone out there tried this? Gotta be a damn site cheaper than ~$300 for a Z32 AFM. If we've absolutely missed something come tell us why it wouldn't work!
- Rowdy & Oosh.
the afm is measuring (acurately) the airflow/change in airflow. The bypass itself will have it's own flow charateristics which the afm will not account for in it's reading, and not end up in fuel and or timing adjustments.
On the cheap side, you can use the new Apexi S-afc II to run a Z32 AFM instead of going the whole hog ecu upgrade.
Yeah you'd have to remap your chip, i thought that was obvious, sorry.
But you have to remap it for a Z32 just as you would any other alteration to the airflow. But once you're tuned to the characteristics of a stocky with a bypass then they'd stay the same it'd be good from there would it not?
So basically you don't know, and in T0nyGTSt 's post he says there's a 10mm difference in diameter (70mm vs 80mm), that equates to 30% more area.
And just coz it aint been tried (to your knowledge) doesn't mean it doesn't work, how'd you think people find this stuff out in the first place?
Edit:
Added rant :(
The size is not the difference between the different afm, its the voltage they send for a certain air flow. By setting up what you propose they would be no way to accurately controll how much air went through the bypass pipe. While the engine/turbo may always recieve the same amount ofn air the airflow meter may have different amount passing through it and the engine would never be tuned correctly.
edit. I dont know if tony gtst has actually measured them both, i know from memory after fitting both they were the same size.
The flow rates in each pipe would be percentage based, depending on relative sizes and mouth properties (a bell mouth sucks better).
Pick someones brains with knowledge about flow dynamics (so i'll have a chat to dad soon) and you should be able to work it out. And as i said before once you've mapped your ECU to it, all done!
Edit:
That's assuming you didn't get stooged, if they bolt staright up and no size difference, just what IS the difference between a RB20 and Z32 AFM?
But why, it's not sampling horsepower, it measures air.
They both have a max output of 5V, i understand if a Z32 has a higher resolution, but that still doesn't invalidate our theory.
It'd still work, maybe not as well, and since you've still got the stock ECU (just re-mapped) a higher sensor resolution wouldn't be usable anyway.
The problem is flow reading accuracy. The AFM is even more sensitive than a MAP based sensor system and has its benifits especially in low end fuel ecconomy.
flow rates will not be percentage based BTW. they vary against more things than you can poke a stick at, most of them are logarithmic and not linea relationships.
Its an interesting idea and you guys seem quite excited about coming up with possibly a new solution to z32 replacement.
my question is, how much power are you chasing, or planning to make?
Apparently lots of people want to "upgrade" to z32 AFMs, when most of the time its not even necessary.
To quote Mr HPI himself, Martin Donnon:-
"other than on CA18 or SR20's there is little raw airflow value to be had in changing AFM's. There are all sorts of black magic rumours that the 300zx 80mm AFM has some sort of beneficial effect on engine power, but the reality is that it doesnt."
"the only reason you would ever substitute a Z32 AFM is in extreme high-boost applications where its calibrated range is higher than that found on the RB20 or RB25. At 1.5bar on, you have slightly better chance of tuning with the Z32 unit, but thats about it."
"If you have an RB20/RB25 powered car , dont rush out and change the AFM for the sake of it. All you will end up with is a massive tuning problem"
Clint32, it seems you are right about the AFMs from 32's and 300zx's both being 80mm, and not 70mm on the 32. (according to HPI mag)
rowdy, while its not exactly answering if your idea will work or not, i found the article interesting as many people inc myself seem to be a bit confused about the whole jist of changing AFMs, and thought it could be useful to readers of this thread.
cheers SLY33
They both have an output of 0-5V but what mA??? I think this is why the Z32 unit maxes out at a higher hp figure.
As for bypassing the AFM with a pipe, that flat out wont work. Any air the engine is going to be asked to compress needs to be measured by the ECU. This way it knows the amount of fuel, required injector cycle etc . By passing it means it wont know to allow for the additional air.
As for tuning the ECU to run richer to allow for air bypassing the AFM, that would mean you would have to make another adaptor after the airfilter but before the AFM, (or install another air filter for that pipe) .
Also i suspect it wont be able to be tuned nicely as when the turbo isnt spooling, i suspect the low vacuum in the bypass line may help the engine stall as it would effectively be seen as a leak in the inlet tract after the AFM but before the turbo. (Nothing to stop the air from going out the bypass intead of into the turbo/IC/throttle body.
I think a cheaper method may be grabbing an AFM off a larger displacement car like an L98 350 Chev and seeing if the wiring can be woked out. Either way a change to the AFM means you will require a change to the tune of the engine EC.
Airflow meter bypass is mentioned briefly in J.Edgars 21st Century Performance and there is also a pic.It goes without saying that you will also need to remap your ECU.But its the same deal with Z32 AFM.Even though both R33 and Z32 AFMs have 0v-5v operating range, Z32 AFM has different calibration,which means that for a given amount of air it flows,it will output less voltage compaired to R33 AFM.Connecting a resistor to R33 AFM will reduce its output voltage,but the moment AFM maxes out, the output voltage,albeit less then 5v(because of the resistor),will probably stay the same no matter how much more air will be drawn into the engine.Not a good idea.
Okay so we have:
* A few, maybe but hard to tune.
* A flat out NO.
* Been done/discussed already.
skyr33
Thank you. Looks like a trip to the library is in order.
SLY33
Tony said the R32 AFM = 70mm and Z32 = 80mm.
Roy
As mentioned we don't expect to get away without a re-map of the chip, and that'd fix it. If the car is gettin x amount of air, but the ECU thinks it's getting less it wont be a problem so long as your map compensates for it.
Roy
As for tuning the ECU to run richer to allow for air bypassing the AFM, that would mean you would have to make another adaptor after the airfilter but before the AFM, (or install another air filter for that pipe).
As mentioned earlier the idea is to run the bypass pipe from the airbox to after the AFM.
Roy
This doesn't seem to make sense to me, NA cars still suck air, and how is two pipes going in to one (bypass and AFM) any different from two throttle bodies into one plenum? That works.
Roy
How is that cheaper, buying an AFM, working out the outputs, making new electronics for some sort of interface. As opposed to a bit of pipe, a T piece, and a re-map? BOTH would still need a re-map as well ofcourse.
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
