Hey all
Recently fitted some new springs to my R33 GTS-t to raise it's belly off the ground (Was WAY too low)
Anyway, now that I've done this, I have a suspension "clunk" issue, mainly from the front drivers side.
I've been back under the car with a breaking bar and socket, and everything is as tight as can be, but I took some careful note of bushes etc, and to me, the bush at the bottom of the shock (in the eyelet) seems to have "come out" on both sides and it doesn't look to be sitting on the pin properly.
Can this cause my "ka klunk" as I ride over bumps to occur, and what parts should I run out to order to fix it.
I'm going away next thursday, and really want this fixed.
https://www.sau.com.au/forums/topic/165097-suspension-noises/
With one of my R32s the front upper arms started making a clunking sound when they were worn. Have you got std rubber bushed upper arms in your car or the urethane ones?
When you refitted the springs did you tighten up the bushes with the car on the ground. From memory when you fit the upper arms you have to torque them up with the car on the ground, which is to ensure the twisting of the bushes(movement of the arm) is within the range that the rubber can take without breaking. It could be now that you have reset the height of the arm that there is wear in the arm from previous height or if the person who lowered the car actually did it properly you may now be forcing the arm into a range of movement that is outside what the rubber can take.
When you fit new arms they make special mention on how important it is to tighten the bolts while the car is on the ground and to me it makes sense to do the same when you alter the range of movement that the suspension arms will be going through by lowering/raising the car.
another cause of the knocking can be stuffed shocks - especially if stock shocks have been used with low springs, now that you have increased the range of movement of the shock I think it would highlight any probs the shock might have.
sorry for not narrowing the options but the above maybe worth considering.
may not be the case with you car
    • See my post here If you put the Haltech in, you won't have to worry about any of that. And, in case you're worrying about my lack of credentials in doing your exact swap, I put a Neo in an R32. There has never been a stock boost solenoid near my car and the Neo's ECU has never cared. Nor should it, because it is electronically impossible for it to care.
    • That's 100% wrong. Did you wire in the boost sensor? If you did not, then that is 101% your answer. Neo ECUs do suck a bit.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
