Hi Everyone.
Some of you may remember this r32. It was for sale a few months ago. I imported the car my self, and unfortunatly it failed compliance due to the 'jacking points' being pushed in more then 20mm. This could have been caused from a number of things, my guess is the car forlifts in japan. The workshop i was using has been shut down, and now im stuck with a car that cannot be 'legally' complied registered.
Everything else about the car is perfect. It drives excellently, it has the power that it should have and it is clean, inside and out.
It is totally ridiculas, but im not going to get into that here because i could go on complaining and winging for ever. Yes i've lost alot of money, and yes i've thought about wrecking it. All because the jacking points were pushed in 2mm more then what is allowed. But i've moved on from cars now and i'm just going to cut my losses and sell it as is.
Basically, the car is is in very good condition. Hard to believe for a car that got rejected hey? The motor is in perfect (82,000kms on clock) and the gearbox is tight and the clutch is bouncy and fresh. The car was resprayed Gold in japan. It is very tidy inside and out, and looks great as you can see from the pics.
All the compliance work has been carried out on this car (full service etc, even though it isn't complied) and i've driven this car about 500kms, just on a dealer plate and had no problems what so ever.
Its a Gold 1990, r32 Gts-t Type M
Manual
Turbo
Aftermarket suspension
The steering wheel was returned to stock as well as the gearknob.
The exhaust, podfilter, gage and turbo timer have been removed, and i will be removing the cd player and radio.
I'm after $5500
Any questions etc, just post, or email at [email protected] or call on 0422373164
Regards
Mondial
post-2280-1176902976.jpg post-2280-1176903000.jpg post-2280-1176903011.jpg post-2280-1176903024.jpgpost-2280-1176903047.jpg post-2280-1176903061.jpg post-2280-1176903076.jpg post-2280-1176903086.jpgpost-2280-1176903097.jpg post-2280-1176903155.jpg post-2280-1176903165.jpg post-2280-1176903175.jpgpost-2280-1176903184.jpg post-2280-1176903203.jpg post-2280-1176903213.jpg post-2280-1176903223.jpgpost-2280-1176903232.jpg
Edited by Mondial
https://www.sau.com.au/forums/topic/165155-sold/
mate the easiest way would be to part it out.
r32's are getting old so a lot of things would need replacing on them.
although it would be a shame to see such a nice car being wrecked, but whatyado
good luck
https://www.sau.com.au/forums/topic/165155-sold/#findComment-3061491
My worst nightmare...compliance...sorry to hear about your bad luck...
Where bouts u located? (if its there i must be blind...)
Yes this car can be used for whatever you want, just not on the road.
You only get one chance at compliance, if it doesnt pass, it doesnt pass.
https://www.sau.com.au/forums/topic/165155-sold/#findComment-3061716
thats so unfair. Surely you couldn't have the points super reinforced or something, then go back to a different engineer, it would probably be stronger than it ever was, and worthy of ADR's.. I would think.
Also can you claim anything throught the shipping insurance, or hold the car yard responsible perhaps?
https://www.sau.com.au/forums/topic/165155-sold/#findComment-3079349
i hope this rule isnt the same for chaasis rails my r33 is on the way from nz both front ones are pushed up on the insides cose some idiot used a trolley jack on it for its wof(rwc there)to jack it up...oh dddddaaaammmmmm.......while im here anyone know if my car can be complainced there using my tein adjustable suspenion??its a personal import..your rules are all over the place and very silly someone needs to clean it up sorry for hi jacking ya thread...
Edited by mr rb25 r33
https://www.sau.com.au/forums/topic/165155-sold/#findComment-3081993
    • Because the drive dog for the steeering angle sensor is present on wheels that came in HICAS cars and not present on wheels that came on non-HICAS cars. Not that I would let that bother me, because HICAS is trash and any excuse to get rid of it is a good excuse.
    • My plan is to replace both Shift Solenoids A and B, and good idea on the Torque Convertor Solenoid as well.
    • I mean, I am always taking donations for a newer model!!  If you'd like to sponsor me. I would gladly get something else!! LOL
    • Interesting.  Great info. thank you.  Give a few days to get that name plate.  I have a busy life most weeks.  I will be in touch.
    • Strange your posting about this being an issue. Move the harness or change your wheels or run more camber etc. Have the thing not touch the thing so it doesn't destroy the thing.  Short answer, no. Slightly longer answer, the factory fuel gauge is measuring resistance. You need to wire in the FPG fuel level sender into the original factory fuel level sender wiring.  I drew you a picture to explain this one The factory strainer is quite long, reaching down into the bottom of the tank. Safe bet your aftermarket fuel pump has a little baby sized strainer that probably doesn't even point down towards the bottom of the thank.  Solution, move the pump lower down in the tank, or fit a longer strainer, or do both. I did both, I've run my tank down to 5L remaining and the car still drove fine.
