Sold
Hi Everyone.
Some of you may remember this r32. It was for sale a few months ago. I imported the car my self, and unfortunatly it failed compliance due to the 'jacking points' being pushed in more then 20mm. This could have been caused from a number of things, my guess is the car forlifts in japan. The workshop i was using has been shut down, and now im stuck with a car that cannot be 'legally' complied registered.
Everything else about the car is perfect. It drives excellently, it has the power that it should have and it is clean, inside and out.
It is totally ridiculas, but im not going to get into that here because i could go on complaining and winging for ever. Yes i've lost alot of money, and yes i've thought about wrecking it. All because the jacking points were pushed in 2mm more then what is allowed. But i've moved on from cars now and i'm just going to cut my losses and sell it as is.
Basically, the car is is in very good condition. Hard to believe for a car that got rejected hey? The motor is in perfect (82,000kms on clock) and the gearbox is tight and the clutch is bouncy and fresh. The car was resprayed Gold in japan. It is very tidy inside and out, and looks great as you can see from the pics.
All the compliance work has been carried out on this car (full service etc, even though it isn't complied) and i've driven this car about 500kms, just on a dealer plate and had no problems what so ever.
Its a Gold 1990, r32 Gts-t Type M
Manual
Turbo
Aftermarket suspension
The steering wheel was returned to stock as well as the gearknob.
The exhaust, podfilter, gage and turbo timer have been removed, and i will be removing the cd player and radio.
I'm after $5500
Any questions etc, just post, or email at [email protected] or call on 0422373164
Regards
Mondial
post-2280-1176902976.jpg post-2280-1176903000.jpg post-2280-1176903011.jpg post-2280-1176903024.jpgpost-2280-1176903047.jpg post-2280-1176903061.jpg post-2280-1176903076.jpg post-2280-1176903086.jpgpost-2280-1176903097.jpg post-2280-1176903155.jpg post-2280-1176903165.jpg post-2280-1176903175.jpgpost-2280-1176903184.jpg post-2280-1176903203.jpg post-2280-1176903213.jpg post-2280-1176903223.jpgpost-2280-1176903232.jpg
Edited by Mondial
My worst nightmare...compliance...sorry to hear about your bad luck...
Where bouts u located? (if its there i must be blind...)
Yes this car can be used for whatever you want, just not on the road.
You only get one chance at compliance, if it doesnt pass, it doesnt pass.
thats so unfair. Surely you couldn't have the points super reinforced or something, then go back to a different engineer, it would probably be stronger than it ever was, and worthy of ADR's.. I would think.
Also can you claim anything throught the shipping insurance, or hold the car yard responsible perhaps?
i hope this rule isnt the same for chaasis rails my r33 is on the way from nz both front ones are pushed up on the insides cose some idiot used a trolley jack on it for its wof(rwc there)to jack it up...oh dddddaaaammmmmm.......while im here anyone know if my car can be complainced there using my tein adjustable suspenion??its a personal import..your rules are all over the place and very silly someone needs to clean it up sorry for hi jacking ya thread...
Edited by mr rb25 r33
 Share
    • I am currently going this route. I am curious how much horse power you put behind the cut bell housing? Collins was telling me I am going to crack it and bluh bluh bluh. Because I didn’t buy the custom fly wheel from him. I am looking for somewhere around like 500 hp
    • Forgot to mention that these are the before pics when I first got it!
    • Thanks @PranK for the updated member status, much appreciated! 👍🏼 Now, about those pics… Unfortunately I could only find ones that I took in the dark. I was soon to discover that underneath it wasn’t in the best shape, but it was mine and that’s all I cared about at the time 😆
    • Oh, and only having done this task yesterday, I've now driven the car ~60km since, and while it is hard to avoid placebo effect and confirmation bias, I reckon that some annoyances I had with the way the car has been behaving have improved. Which....kinda makes sense, I guess. If the bushes were really stiff and resisting rotation, they would have been contributing to the effective wheel rate. And if it was more so on one side (which it was, because one side was worse than the other) then.... you might imagine that the additional rate would be asymmetric, and potentially even different between compression and rebound. And so... the car has been twitchy at higher speeds - like freeway on ramps. It really shouldn't be. The wheel alignment is good and there are no (other) known problems elsewhere in the suspension. But at 90-100 on a long sweeping ramp, tiny steering wheel motions would make it feel like it wanted to rear steer. Quite nervous. At lower speeds it would heave about in a manner that it didn't use to. Didn't want to put power down, etc etc. Now...seems to behave better. Am going to have to concentrate on the various corners where it has exhibited weirdness, on the rare occasions when I can get a decent run at them without Methanial getting in the way in his D-Max/Ranger/LDV Van/etc.
