Remember the Yellow Bird?
RUF Announces the CTR3 Supercar
Exactly 20 years after the legendary CTR “Yellow Bird†and 10 years after the second CTR, RUF announces the all new CTR3. The RUF CTR3 was presented at the grand opening of the new RUF facility in Bahrain. While the first two CTR generations still had their engines in the rear, the new CTR3 has a mid engine design. However, one thing that the CTR3 has in common with its two predecessors is that it is a pure driving machine. The CTR3 is made to involve the driver in the driving experience.
The mid engine design provides exceptional balance and agile handling, while the longer wheel base provides better driving stability at high speed. The body of the CTR3 is a completely new development which is not based on any existing mid engine concept. It is aerodynamically designed for high speed. The body is constructed in steel, aluminum and kevlar-carbon. Zinc dipped steel is used for the front structure and the passenger compartment. The engine and transmission are fixed in a space frame and birdcage. The passenger compartment is protected the latest version of the famous RUF Integrated Roll Cage which is integrated into the A pillar and birdcage. The doors, with integrated side impact protection beams, and the front hood are made of aluminum. The body shell is made of kevlar-carbon composite.
The body styling was created by Ben Soderberg, who is responsible for the RUF design.
RUF has 30 years of experience with turbo charged boxer engines. The CTR3’s twin turbo charged 3.8 liter flat six cylinder engine has an output of 700 bhp at 7,000 rpm. The maximum torque is 657 lb-ft at 4,000 rpm. This engine design combines a compact construction with high performance. Each turbo charger is provided an intercooler which is placed in front of each rear wheel.
The sequential shift six speed transmission in the CTR3 is a new design and is transversally mounted. It can manage torque of up to 885 lb-ft. A shift indicator on the dashboard shows the gear in use. A limited slip differential is provided to maximize performance.
The sport suspension is designed for high level driving dynamics and safety. The front axles use McPherson struts and an anti-roll bar. The rear axles utilize motor sport technology with horizontal coil over shock absorbers fixed over push rods connected to the wheel carriers.
The brake system is designed to match the high performance of the engine and suspension. Both front and rear axles utilize 6 piston fixed light alloy calipers and ventilated, cross drilled ceramic composite discs. Each brake disc is 380mm in diameter. A specially designed Bosch anti-lock braking system is standard.
The CTR3 rolls on forged aluminum wheels with central locking. At the front 255/35 ZR19 tires are mounted on 8.5†X 19†wheels, while at the rear 335/30 ZR20 tires are mounted on 12.5†X 20†wheels.
The interior can be designed to the customer’s taste, from a functional light weight finish to sporty luxury finish with a leather and alcantera. The aluminum gear shift lever for the sequential shift transmission is a central unit to the interior. In addition, the 260 mph speedometer shows the driver that the CTR3 is made for high performance.
The lightweight construction allows for an empty weight (according to DIN) of 3,086 lbs. The result is a power to weight ratio of only 4.4 lbs per bhp.
The performance of the CTR3 is incredible. The acceleration from 0-62 miles per hour takes only 3.2 seconds. The top speed is 235 mph.
Source:Rufclub.com
https://www.sau.com.au/forums/topic/165168-ruf-ctr3/
specs look sweet and it does look pretty cool, but not zonda/enzo supercar looking.
does look like an audi mating with a porsche
Yeah the pictures doesnt tell the whole story. From the specs it actually has a supercar proportion about 1944mm width and 1230mm height I remember. Would look much more dramatic in metal.
https://www.sau.com.au/forums/topic/165168-ruf-ctr3/#findComment-3060901
Finally new CTR! Agreed does look like Carerra GT might be based on it. Very nice looking, Love the specs, Cant wait for top gear to Test drive it :P i know i never will :)
Not based on the Carerra GT. Ruf designed their own chassis, 977 turbo front end suspension geometry. Maybe the Caymen rear lights and mid mount engine made it resembles the Carrera GT.
https://www.sau.com.au/forums/topic/165168-ruf-ctr3/#findComment-3060914
Its hard to know what to make of it. Parts if it are sooo sexeh. other parts are ...ummm. To my mind the lines of the car are out of proportion. Take a look at the top pic. If you swung the roof turret around the car might look better driving in reverse.
Wouldnt mind havin it parked in my garage tho.
https://www.sau.com.au/forums/topic/165168-ruf-ctr3/#findComment-3061164
