Remember the Yellow Bird?
RUF Announces the CTR3 Supercar
Exactly 20 years after the legendary CTR “Yellow Bird†and 10 years after the second CTR, RUF announces the all new CTR3. The RUF CTR3 was presented at the grand opening of the new RUF facility in Bahrain. While the first two CTR generations still had their engines in the rear, the new CTR3 has a mid engine design. However, one thing that the CTR3 has in common with its two predecessors is that it is a pure driving machine. The CTR3 is made to involve the driver in the driving experience.
The mid engine design provides exceptional balance and agile handling, while the longer wheel base provides better driving stability at high speed. The body of the CTR3 is a completely new development which is not based on any existing mid engine concept. It is aerodynamically designed for high speed. The body is constructed in steel, aluminum and kevlar-carbon. Zinc dipped steel is used for the front structure and the passenger compartment. The engine and transmission are fixed in a space frame and birdcage. The passenger compartment is protected the latest version of the famous RUF Integrated Roll Cage which is integrated into the A pillar and birdcage. The doors, with integrated side impact protection beams, and the front hood are made of aluminum. The body shell is made of kevlar-carbon composite.
The body styling was created by Ben Soderberg, who is responsible for the RUF design.
RUF has 30 years of experience with turbo charged boxer engines. The CTR3’s twin turbo charged 3.8 liter flat six cylinder engine has an output of 700 bhp at 7,000 rpm. The maximum torque is 657 lb-ft at 4,000 rpm. This engine design combines a compact construction with high performance. Each turbo charger is provided an intercooler which is placed in front of each rear wheel.
The sequential shift six speed transmission in the CTR3 is a new design and is transversally mounted. It can manage torque of up to 885 lb-ft. A shift indicator on the dashboard shows the gear in use. A limited slip differential is provided to maximize performance.
The sport suspension is designed for high level driving dynamics and safety. The front axles use McPherson struts and an anti-roll bar. The rear axles utilize motor sport technology with horizontal coil over shock absorbers fixed over push rods connected to the wheel carriers.
The brake system is designed to match the high performance of the engine and suspension. Both front and rear axles utilize 6 piston fixed light alloy calipers and ventilated, cross drilled ceramic composite discs. Each brake disc is 380mm in diameter. A specially designed Bosch anti-lock braking system is standard.
The CTR3 rolls on forged aluminum wheels with central locking. At the front 255/35 ZR19 tires are mounted on 8.5†X 19†wheels, while at the rear 335/30 ZR20 tires are mounted on 12.5†X 20†wheels.
The interior can be designed to the customer’s taste, from a functional light weight finish to sporty luxury finish with a leather and alcantera. The aluminum gear shift lever for the sequential shift transmission is a central unit to the interior. In addition, the 260 mph speedometer shows the driver that the CTR3 is made for high performance.
The lightweight construction allows for an empty weight (according to DIN) of 3,086 lbs. The result is a power to weight ratio of only 4.4 lbs per bhp.
The performance of the CTR3 is incredible. The acceleration from 0-62 miles per hour takes only 3.2 seconds. The top speed is 235 mph.
Source:Rufclub.com
https://www.sau.com.au/forums/topic/165168-ruf-ctr3/
specs look sweet and it does look pretty cool, but not zonda/enzo supercar looking.
does look like an audi mating with a porsche
Yeah the pictures doesnt tell the whole story. From the specs it actually has a supercar proportion about 1944mm width and 1230mm height I remember. Would look much more dramatic in metal.
https://www.sau.com.au/forums/topic/165168-ruf-ctr3/#findComment-3060901
Finally new CTR! Agreed does look like Carerra GT might be based on it. Very nice looking, Love the specs, Cant wait for top gear to Test drive it :P i know i never will :)
Not based on the Carerra GT. Ruf designed their own chassis, 977 turbo front end suspension geometry. Maybe the Caymen rear lights and mid mount engine made it resembles the Carrera GT.
https://www.sau.com.au/forums/topic/165168-ruf-ctr3/#findComment-3060914
Its hard to know what to make of it. Parts if it are sooo sexeh. other parts are ...ummm. To my mind the lines of the car are out of proportion. Take a look at the top pic. If you swung the roof turret around the car might look better driving in reverse.
Wouldnt mind havin it parked in my garage tho.
https://www.sau.com.au/forums/topic/165168-ruf-ctr3/#findComment-3061164
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
