hey guys im about to install my front mount on this weekend on my r33 gts-t series 2, its a full sized hybrid copy, just need some advice on howfar i have to cut the front bar and what would need to be cut ?
if i can get some help that would be great
thanks guys :)
https://www.sau.com.au/forums/topic/165169-intercooler-fitting-on-a-r33/
plan before u cut!!!!
if you dont know where to cut i think u are going to struggle....just recently had one fitted.....thought of doing it myself but luckily i spoke to Mr G who came to my place to do it for $200....well spent....if i tried i would have failed and had no car until someone could help.......
if u still want to try urself have a look on youtube, there is a clip on how to do it....doesnt show it indepth but gives u something to start with...
good luck!!!
The most difficult part it where to cut the wholes in the engine bay, everything else is pretty easy..
to cut the wholes just use a drill to make a circle then chisel them out...
to cut the front bar you will need a special tool for this as its not easy to do wit a hack saw or anything..
Its worth doing yourself for the experience and a good acomplishment when finished..you can say you done it..
But for $200 to get it installed its really worth it..
Cheeers Daniel
Common sense will help you get through it, the kits do allow for some leniency so you do have to be 100% spot on (maybe 95% lol). Just use the guide in the DIY section for where to cut the hole for the piping. Once you have all the piping setup you can judge where the intercooler will go and make front bar cuts from there.
    • Some sense has prevailed! What kind of idiot spends money on intake, heads, and cams for a N/A motor in 2025? Lol. What maroons. Source:I am King Maroon.
    • So, cams are not getting installed......yet  Had a good chat with MX5 Mania about intakes, they recommend not to get ITB's, they recommend a plenum style for the NC So, one of these puppies is being ordered, with a larger TB to suit, when it arrives from the US the car will go in for the cams and intake I'm also getting a fancy rear box bit for the air filter box which will suit the new TB size
    • Clamp meter is pointless. Unless you're trying to keep average current under a set value for some weird reason (maybe you undersized your wiring?), then you'll get no useful info. What you're really trying to target is the flow of fuel coming back to the tank. You want some, but not a lot. You also want to make sure fuel pressure remains stable.   So, fuel pressure gauge, and fuel flow gauge. Set it up from that.
    • Aside from the fact it is likely fuel related if it is black, the symptoms otherwise sound like worn valve stem seals. Oil gets past the worn seals when the engine is off and burns when the engine starts. If it happens on deceleration while driving (puffs of white smoke) that is another valve stem seal symptom because oil gets sucked form the head into the combustion chamber under vacuum with the throttle closed. They can be replaced in the car if you have some way to keep the valves closed while working (eg compressed air into cylinders) but is much easier with head off.
    • Alright, fair enough. Expected as much. Possibly, yes. However the kit is apparently not including every single hose and it is out of stock too.
