Hope you didnt miss the camera car in the 90 zone yesterday south bound!
Doesn't count... he is always there... It's either the straight between Mooney bridge & Mt White weigh station, the bend in the 90 zone, or at Jolls bridge either on the left tucked away in the breakdown telephone spot or the between the wall in the middle............anyways I am usually doing the speed limit or at the most 5km over..just not worth it these days......
Its just like a fixed speed camera that damn wagon - its always there! ... oh and don't forget parked in the line of cars at Kariong after the servo...
They have camera cars in NSW!? I didnt know that!
I saw a Highway Patrol car yesterday in my travels, was waiting behind it at a set of lights, and you can see on the back parcel shelf that there's a camera on a small stand with all the wiring and stuff, and I could just make out the silhouette of one mounted on the dash at the front too...
they've been doing the whole camera thing for over 2 years at least.
whenever i get pulled over i always get out of my car, i get nervous/defensive if someones talking down to me for some reason and i end up nervously giving out jabs or babble on about stupid shit. so i get out and they always say, 'mate, just remember we've got a camera in the car, ok?'.
they probably didnt make enough money booking people over the easter weekend.
Correction... They got me defected over that certain weekend lol :( Cost me over a grand to fix everything up and still haven't paid my fines! :)
i found a close up pic of one of those video recorders in highway patrol cars
Here V recorder
Josh
Was driving home from work at 3am in the morning down Epping road just off the Princess Highway underpass heading towards Lane Cove. Doing the speed limit, saw a HWP car going in the opposite direction. I look in the rear view and...yes you guessed it - he did a u-turn.
Followed me for a few hundred meters and then decided to flash his blue and reds.
Out of the car and he says..."good morning sir, random breath test.."
MY @RSE RBT!!
How can it be random when he did a u turn and then followed me for so long?
But i drive a Skyline, so i cant expect any better from our law enforcement officers. Good on you boys!
Mike.
MY @RSE RBT!!
Mike.
Yeah along that rd epping rd, they do alot of "random" breath tests, my brother is a red p plater driving a mazda 323 sp20 and they came flying out of a side street and pulled him over for a "random" breath test and pretty much anytime at night a red p plater is driving in our area they seem to automatically pull you over - fair enough as this will hopefully drive home the message about getting caught but they are in the same boat as us.... Mind you none of the police pull me over when they see me like last night a paddy wagon on my way home thru gosford caught up to me at a set of lights in the other lane then followed slowly for like 2mins... then gone... 3 mins later he re-appeared in the same lane and drove past me - Was full on expecting to be breath tested or pulled over but nah they musn't like the 4 doors lol
I was pulled over for an RBT thurs night at hornsby heights, im a good boy so was all good :(
Oh, and saw two XR6 highway patrols (unmarked and marked) race a plane today!
each time the xr6 turbos won! :P (true story!)
    • Started sifting thru my brakes to decide which ones I will run on Clem   Made me think I should just put them all on Silver...for when brake fade just isn't an option   Should be able to bump rotor up from 343x32 to 348x36 off Supra. Not sure if the Supra annulus is right for the Alcons or APs but trying g to find a used Supra\M4 rotor to test fit The Alcons seem to gain 1-2mm clearance which all helps
    • So car is getting a few mods to the cage and some jacking points welded in Meantime Ol Silver gets a new gearbox and shiny clutch.  Old Box is being set aside for Clem
    • Probably speedometer itself if the odometer is ticking. If the needle is stuck from a bit of grease or something that can cause it to stay at 0. Or a cracked solder joint in the speedometer can do it too.
    • Thanks Fella’s   to take this off topic and to elaborate a bit more. I have an rb25/30 going into a r32 GTST.. expected to make around 600-700hp. Would you?   A) R34 GTT box   B) CD00#?  I’ve seen a few posts about the CD swap and sounds fairly involved with making it fit etc but if it’s worth the work then I’ll go that way
    • Lower at the hubs. Funny I forgot to mention that part. Do this pull here I turned the camera off too soon but the graph shows a drop at the top and that was because the pipe from the turbo blew off. The tuner said we could’ve made possibly another 15 whp. He also added if I switched to ethanol we could up the boost some more as well. I was comfortable capping it at the most of 20 pounds. Turns out the turbo pipe just needed a new worm clamp. Got home replaced that then did a third gear pull from 3k to 7200 rpm and the power was great to the top. I just got an ecu mounting bracket from IEE that I need to try and get everything to fit well. It’s a PITA to get the harness and ecu fit properly behind that kick plate
