Happy Birthday Dee - Drinks On Sat Night So Come On Down
adznight
 Share
Howdy all, was Dee's birthday yesterday and yeeeeeeeees, forgot to post a thread. Just want to say HAPPY BIRTHDAY DEE!
For all those who are free this coming Sat night we'll be hitting Switch @ Knox Ozone for a BIG night SAU style so feel free to come down!
Where - Switch Bar Grill (Knox Ozone)
When - 7pm onward
Bring - Your drinking boots
See you all there :sorcerer:
Hahaha - you use nicknames we dont even use!!!
Plus - if you can come out this way to play with your car, surely you can celebrate a friends bday :)
I use nicknames... in half there.
The full part is "The Gully Moles" in reference to some ladies that we knew once... who were... well... nice enough
Working on my car is one thing, getting drunk and then trying to workout how to get home when its 40mins away is another :P
Working on my car is one thing, getting drunk and then trying to workout how to get home when its 40mins away is another :nyaanyaa:
Gully Moles, hahaha. Must be a common theme, I think I know a few.
As for the 40 min drive, welcome to our lives, that's a $60 taxi fee and the = a LOT of drinks!
Happy birthday Dee,
If I was less whipped i would be in like Flynn, someone take a laptop and post messy pics! I have a date with my new ute saturday night........ let the loving begin. :nyaanyaa::happy::( Navara :):wub::wub:
Knox is 5 mins down the road for me, so ill try drop in. Dont know any of you, so maybe ill just make some noise when I drive past so someone notices me.
Hahaha, trust me if you make noise you'll have us out there quick smart drunk too! :D
 Share
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
    • Deeve, I don't suppose that you've made any progress on this? My Stagea has the exact same problem, and just like you, I've read through as much as I can online, with no real progress. My car isn't throwing any codes at all, which is a little frustrating. I've changed plugs, checked the wiring and harness. A new MAF gets here next week, but I'm not hopeful it will solve the issue.
    • I installed it all myself,  It was really easy to install.  I got a professional to do the degas/gas.
