Thanks Buster. Ill try him again next set of tyres, but last time i got a price off him for the 540s they were like $10 cheaper each then the Dunlops. So was quoted something like $420 each for 235/45/17 (may have been 235/40/17)
Decided to stick wih Dunlops as i have nothing but praise for the guys who sell them in Sydney.
has anyone used 540's in 16inch? say 225/50 on a std rim? Im wondering if they will perform better than a 17 or 18inch street tyre in terms of ->do you get sidewall flex/rolling on hard cornering as you would with a 16inch street tyre?
Im tempted in fitting them to std rims for track, as the 16in tyres seem heaps cheaper.
cheers
I've not used either 540s or 16" track tyres, but I do use dunlop d01js in 17s....and one of the major improvements in R tyres is less sidewall flex due to much stiffer sidewalls.....so, 16s should still be great. The only real improvement from low profile tyres eg 17s, 18s, is due to stiffer sidewalls.
Sly, i was (and will do when i need new tyres) going to do this on the stockers, but apparently the stocky rim is only 6" wide. It is more ideally suited to a 205/55 16 and they're available in 540s. They should hold on as well as a 17" when warm.
I'm guessing that of you run reasonable pressure you won't get much roll.
205's eh? sounds a bit small but if they are cheap it would be ok! do you know what these can be had for ronin?
are std rims only 6 inch wide? i thought maybe 6 1/2... ive got 225/50 street tyres on stockies that look fine, do bridgestone make 225/50 16 540's?
cheers!
Yes they do make 225/50/16 as it is this size that my boss uses on his vn comodore race car.
I know you guys are talking about circuit racing but how would these tyres go for drag racing?
With 200rwkw in an r32 using 245/40/18s with about 50 % tread iam having big traction problems and cannot get my times down to where they should be.
My plan is for when i go to the creek in about a month to fit 2 540s (used ones from the race car) to my stock rims to go on the back using about 20 psi in them.
Will this improve my launches ect.... ???
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
