for sale
r33 a set of kei office coil overs with tops no leaks looking for 750 down to 650
r33 a 3 inch dump / front pipe good nic no rust or dents 100
r33 gtr n1 nostrils bought from just jap for 140 never used for 130 down to 100
top end of r32 rb20 head inlet manifold polished coil pack cover not sure what its worth so make a offer
to4 garret non ball bearing .6 front and 1.15 rear not chinese brand new cost me 1100 will sell for 850
stock exhaust manifold heat sheild 20 bucks
r33 rb25 t 6 coils and loom 100 bucks
r 33 turbo rubber intake good nic no cracks 50 bucks
pics of some stuff
http://s135.photobucket.com/albums/q147/si...a%20S13/r%2033/
located in sydney welcome to come check m out
post up or pm if u r interested will post at buyers expense
selling as i have to much stuff and too much debt
Edited by KLR33
  • 4 weeks later...
howdy, intereseted in coil packs and loom (it is for a r33 gtst?),can u tell me the condition of coil packs and why u are selling ? where are u located? cheers Damo
Edited by madaz R33
condition of coil packs is good no cracks or burns
i m selling because i sold my r 33 so i dont need the spares
located 5 mins from liverpool
pm me if u wana come past n check m out
cheers
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
    • Silly question, as I bet you've checked already, but the motor turns over by hand yes? I suspect Neil has a spare starter, though if not, I believe I have a spare R33 (or two) starter.
    • Yeah just run one of those posts to the Link like GTSBoy said. From google it looks like a "mishimoto boost controller" is a manual boost controller. Since you already have the link just buy any MAC valve and plumb it in where the mishimoto is now. Wires to the solenoid should come from the Link's / standard loom boost control wiring (I guess you have an r32, not sure if it is gtst or gtr, if it is GTR where is a 2 pin connector near the engine bay fuse box/injector resistor for that purpose, assuming the standard boost controller is gone)
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
