My new Tomei (Nissan) Z32 was delivered today
The mesh looks better
The sticker looks marginally better, and slighly different design.
There is definatley no mention of 'Nissan' imprinted in the plastic.
From memory, the sensor looks to be a diferrent colour?? (maybe wrong there)
The top plastic cover plate looks to be a bit dogey though, although if all the interior bits are OK, it won't make a difference.
Here's some pics....
  • Replies 106
Posted Images
Ben,
Yep I'm around the same volts as you and suspect same power; all though I never did dyno it once it was running properly. I went to give it a power run and it was pumping the lifters; that was sorted and never threw it on the dyno again. :D
But yes ~4.3v and it made 180rwkw then valve floated and power dropped.
The stock afm was max'd out, dropped the z32 in and was around 4.3v as you are. Stock 270cc injectors were maxed out also. :rofl:
Same boost levels too but with vg30det turbo. The heads had a little work, usual port/polish, multiangle valve jobs & valve deshroud.
There's quite a big difference in airflow from 4.3v to 4.7-4.8v. Another mate was maxing his std afm out at ~180rwkw, dropped the z32 in retuned and did 4.7v at 270rwkw.
Won't be long before I'm pushing the boost up with the gt30; should get my rb26 pfc and fit it up this week.
Nice to know cubes. Should go well once you tune it up and get the gt30 going!
Ive got to put my 450cc S15 injectors in then I'm heading for a tune also. I suspected that the difference between 4.3v and over 4.8v would be pretty huge.
I'll be happy with about 230-240rwkw.
Hopefully I will get the flow reversion thing sorted.
  • 3 weeks later...
OK peeps,
Finally swapped AFM and had a tune
It works ! Yeah !
Just swicthing the AFM bfore goijng on the dyno and the car is started and hiccupping and splutterring and telling me "PLease Birnie, i need a tune now" which is the result i was after/expecting going from a dodge AFM/tune to a good AFM.
All tuned and it hit cell 16 down the vertical on about 17psi ( i think that was about 4400 on the volts reading)
Before with the exact same setup with dodge-AFM it hit cell 20 on 13psi.
So as far as I'm concerned, the dodge ones ARE out there.
I don't actually know but i still suspect a bad batch going around rather than some dodgey chinese peeps trying to rip people off.
So yeah, if you happen to get a dud, check fr leaks first cause i had some shockers, but other than that, take itback and ask for it to be checked or replaced.
The worst part is you lose your tuning money which really sucks cause that's the most expensive part!
Luckily i had the 1st tune done on the road with a bud so i was only out of pocket $200
So there you go, I'm sorted.
:thumbsup:
i tested out my mates rb25 afm the other night. at 13psi with a 3076 it was reaching 4.9v and that was only about 270hp. we are going to remove it anyway so that isn't a big issue, but first we need to sort out a few issues we have, such as the intake pipe sucking shut, and an overly restrictive intercooler.
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
