it doesn't go anywhere. it should just have a rubber pipe with like an updside down snorkel looking thing on the end. it just breathes to atmosphere.
thanks mate,
should be able to just leave it off then?
i have a couple other breathers blocked up, one is off the water/air rail near the oil cooler and the other is one of the lines from the ACC valve
if uve blocked the breather up id unblock it before u cause damage. blocking the end causes pressure to build up and then it blows seals out spits oil onto exhausts an causes fire. but u dnt have to if u dont want to
