Hey guys, just wondering if this would work well for my street 25-t aiming for 250-300rwkw???.....anyone else using the same sort of setup??? i spoke to jim, and he said the full monty would be something i should look into. But he also says the full monty is a clutch which you dont need to customise, so in theory everyone has the same clutch specs if they buy a full monty from jim correct???
  • Replies 44
This isn't going to be a direct answer but, if you are honest about what you intend to do with the car when you talk to him you can trust whatever he recommends.
cheers, but he recomends just machuine the stock flywheel, whereas alot of ppl on this forum think thats dangerous, and ive seen good results with ppl using a lightened one.
thanks
The flywheel you suggest is far too light to be used with this clutch. Machine the standard flywheel. It creates no problems whatsoever. Stories of machining related flywheel failure are just that...stories, fallacy, BS, rubbish, rumour, garbage, and whatever else you want to call it.
hrmmm. ask benm then buddy.
who needs legs or a firewall anyway.
hmmmm. Pull your head in buddy.
I will put any money you care to name on the notion that benm's flywheel had a fault to begin with.
I'm speaking from my experience with my car not from what I suppose is fact based on someone else's car.
if you want a steel (aka billet) flywheel, jim has a guy down the coast who does custom job's. he's currently making one up for me to suit an 8" twin plate. cost is around $600
I run the ORC flywheel and have NO issues with it, SK told me if your not using the lightest one available ur wasting power/energy/whatever.
true if its for a circuit car only
put that car on the strip and have fun getting it off the line and keeping it on boost.
There is a difference between lightening a standard flywheel by machining it and machining the flywheel to get the surface perfectly flat. The first is no good imo, the second is standard practice.
i don't really agree 100% with that. I agree that lightening a standard flywheel is a bad idea. and I'd agree that when replacing a stock clutch plate and pressure plate with a new stock clutch plate and pressure plate that it's standard practice so machine the flywheel and there is no problem with it. BUT when replacing a standard clutch with an upgraded (more agressive) friction material, and replacing the standard pressure plate with one that has a much higher clamping force I would personally NOT reccomend re-using the stock flywheel. it's a bad idea in my book.
Failures in the factory flywheel where heavier than standard clamping loads were used are both:
A/ Few and far between
and
B/ Debatable as to whether it was even the clutch that caused the failure.
I have used one of Jim's clutches in my car for a very long (and very harsh) period and had no issues whatsoever. In fact, the clutch (without even being rebuilt) was fitted to another car once it was removed from mine and is still going strong to this day.
When i did my clutch just over 1.5yrs ago.All i did was rub back the flywheel surface lightly with emery paper.But next change will definently get a machineing.
A better clutch will engauge quicker,catching the revs quicker,than a stock one.Also a stock one will slip a a certain power level where as the more upgraded the clutch gets the more power it can handle.A standard flywheel will make the car rev slower to begin with but will hold the speed better at the top end.A lighter flywheel will rev quicker but wont maintain top speed as well.
This is where power comes into play (powerplay LOL).If the car has power it will rev to redline quicker and hopfully negate the feeling that the car isnt holding the top end as well.It is really noticeable in a car that hasnt got much power but has the lightened flywheel.Because the power isnt there to hold it at peak power.
Have you ever driven gran turismo 4?
Buy a bone stock R32gtst .Go and buy all of the flywheels and then buy twin plate and single sports clutches and hit the super long test track.Then sit there and rev the car and take note if it revs up quicker with the different flywheels.Then do a high speed run with all of the clutches noteing how fast u reach certain speeds and how easily it holds the top speed.Do the same but now do it with the different clutches.Now do it up with zort,filter,front mount & ecu and stage 1 turbo.Do the same and see what the results are.
Do timed 0-400m tests.Also 0-1000m tests
(do this from stock thru to racing flywheel)
dude gt4 is a computer game and it's not very realistic :mad:
    • So, what did you decide? If these items were going in and out of stock, you could at least order the two in-stock pieces. Also, I'd say the stock bit of airbox isn't that restrictive to your NA motor. To test if it is, fit a vacuum gauge between the airbox and throttle body. At WOT do you measure any vacuum?
    • Hey guys I have a 2001 Nissan stagea vq25det, I don't have any engine lights and not really any issues running but I was curious to see if I could use my obd II scanner to find anything that was hidden and I plugged my scanner in and it just said "Low voltage cannot scan" does anyone know how to fix this or what this could be?
    • Sadly we have something in common, our Skyline's like blowing up electrically 😢
    • So, no videos, but, the FAB9 Elite manifold and 68mm Bosch throttle bodies are in stock, but, not the rear part of the air box The FAB9 rear airbox thingie is made with a 3" intake pipe, to suit the 3" intake pipe size of a 68mm throttle body  When they get some more in stock is currently unknown as I'm waiting for FAB9 to reply with a ETA on resupply, my assumption is they outsource their plastic printing stuff to "china", and with the current "tariff war" going on in 'Merica it could be on hold for an undisclosed time Should I pull the pin on the Intake and throttle body, and wait for the airbox?????, that's what I'm thinking... 1. Would the standard 2.75" OEM intake on the air box really be that much of a restriction compared to the 3" naturally aspirated?????? 2. If I don't get the 3" FAB9 airbox fitted at the same time as the intake and throttle body will it need a retune, when/if it eventually turns up?????? As I'm impulsive, to a fault, decisions will be made within....."what's the time now"???....let's say 12 hours......LOL
