r33 gts-t, basic mods include front mount, hks intake gutted cat, 3.5 cat back, NEW turbosmart boost tee, factory turbo.
Got use of a dyno to try to sort ourt whats goin on with my car and after asking heaps of people questions bout it ill be f**ked if i know whats goin on!
Cant seem to boost past 9.5 psi(180rwkw)(mixtures were fine) on dyno wothout it feeling like its mis-fireing or cutting out. been told it definetly wont be fuel cut at that boost. have replaced plugs thiknikg that might be a prob, gapped to 0.7mm. have replaced all boost lines. anything below bout 9psi and car seems to run and pull fine
wondering if anyone might know whats goin on, been told bout a factory boost cut, if this might be so whats the cheapest way to get round it.
any help would be much appriciated asap due to sitting 15m from a dyno as we speak lol!!
cheers
brett
What are you just doing a power run with those mods? Have you got any tuning device? Safc or anything? If not then id say its your ecu mate and you cant do anything to get around that without an aftermarket ecu or piggy back
Get a better boost controller would be a start and finish to all problems there, dont really aggree with a boost tee
yeah been told that for a start but i dont really understand how it could fix my problem, 10psi boost is 10psi boost as far as i know, correct me if im worng though.. also has anyone used one of the jaycar electronic boost controller kits?
as for the fuel cut, i have been told by more than one person that would know that it wont hit fuel cut till at least 12psi minimum... as i say im only going by what i have been told by other people.
na got nothing tuning wise yet, just doin power runs to check boost and ratios. think it might be time for a computer lol..... anyone got any recomended computers? are PFC's still availiable anywhere? if not what are the new wolfs like? or e manage?
thanks for the help too...
theres been numerous threads on coil packs, good way is to pull them out look for arcing marks on the steel casing, also at night if lift the bonnet in darkness you can look at the pretty sparkies arcing as well :closedeyes: go for pull them out and check for arcing its easy and takes sweet fa time to do. BTW is it missing under higher load? ie 4000 and up? It could be coils. GL with that
yeah definetly on higher load, usually from 4-6 or so...
Stock computer doesn't like anything over 10psi in a R33, some people have got upto 12 but most can't get past 10psi with factory ECU. I couldn't get past 10psi, now i have a PFC and have it tuned to run 10psi low and 13psi high. 196rwkw at 13psi, but tuner did say it went over 200rwkw but wasn't happy with knock levels and went with a safe tune, thats what i wanted.
taking the plugs to .7 for relatively little boost increase is not good.
.8 at the MOST you should need for a basic setup.
Take the plugs back out to .8/.9 and check the coil packs
ended up being the coil packs, hairline cracks in em, now runnin at 13 and goin great!
