wannabeslida Posted April 21, 2007 Share Posted April 21, 2007 (edited) Was trying to track down why the 4wd system was turning off on the GTR after about 5 mins driving ETS error 3 - right rear speed sensor error. Thought it just took a while to show up but now realise it was when I go around a roundabout or sweeping corner near home turning gently to the right. Found the following when trying to look at the sensor/wiring. Any ideas on what causes this and how to fix it so that it doesn't occur again? I can't see any bracket/bolt that has come undone that allows it to move out from the diff, is there an internal retainer that may have come off, if not, what holds the driveshafts to the diff? The only thing done recently was I had a HICAS Lock bar fitted by workshop and noticed a few bolts left untightened etc, could the workshop have caused this? Edited April 21, 2007 by wannabeslida Link to comment https://www.sau.com.au/forums/topic/165470-help-rear-drivehaft-popped-out-1-inch-wtf/ Share on other sites More sharing options...
wannabeslida Posted April 21, 2007 Author Share Posted April 21, 2007 Can't get the attatchment to show, Link to comment https://www.sau.com.au/forums/topic/165470-help-rear-drivehaft-popped-out-1-inch-wtf/#findComment-3064898 Share on other sites More sharing options...
Abo Bob Posted April 21, 2007 Share Posted April 21, 2007 Recent work in that area suggests you go back to workshop for a checkup. pm sent. Link to comment https://www.sau.com.au/forums/topic/165470-help-rear-drivehaft-popped-out-1-inch-wtf/#findComment-3064988 Share on other sites More sharing options...
Abo Bob Posted April 21, 2007 Share Posted April 21, 2007 Here it is. It looks like the circlip that goes on the half shaft has been left out. Need to remove the half shaft and put one on then shove it back in and bob's your uncle. Link to comment https://www.sau.com.au/forums/topic/165470-help-rear-drivehaft-popped-out-1-inch-wtf/#findComment-3065002 Share on other sites More sharing options...
sh@un Posted April 21, 2007 Share Posted April 21, 2007 these guys have a mvric licence or what Link to comment https://www.sau.com.au/forums/topic/165470-help-rear-drivehaft-popped-out-1-inch-wtf/#findComment-3065004 Share on other sites More sharing options...
wannabeslida Posted April 21, 2007 Author Share Posted April 21, 2007 Thanks for adding the photo Abo_Bob. I got under the car and had another look, this is the corner that all the rubber boots in the driveline were replaced while they did the Lock Bar, good chance that was when the circlip was forgotten. Will call the workshop Monday and get fixed. Anyone know if this is safe to drive to the workshop or is it a tow only, have to drive about 35 mins to the workshop that did it that is all? Thanks Link to comment https://www.sau.com.au/forums/topic/165470-help-rear-drivehaft-popped-out-1-inch-wtf/#findComment-3065057 Share on other sites More sharing options...
