Hey since I smashed my car on the weekend when some bastard cut in on my lane and i swerved to miss him and hit the car in my left lane. The perpetrator just driving off and i was too slow to get the plate. Now i am going to have to pay for the insurance, so instead of getting a 1996 GTS-T SII Skyline for around $25 + $expensive insurance with my now crap rating. I was thinking i will get a 180sx for around $12 and just get 3rd party fire and theft and save $3k/year on insurance.
So are 180sx's any good. I would prefer one with a silvia front end, because pop up lights are sooooo 80's.
Do the 180sx's use the same 2 litre turbo in the GTIR's, as i dont think much of them, although gutsy a friend fo mine has a GTIR which spends half its life in the workshop.
Anyone got any thought on what I should do?
https://www.sau.com.au/forums/topic/1655-180sx/
Okay
Well 1989 model 180sx have the CA18DET, 1.8litre Turbo 4 cyl, the ones with the rounded nose 1991 onwards have the same motor as the GTi-R, the SR20DET. Expect to pay between $12,500 and $15,000 for a early model SR20DET 180sx. They're a good car - pretty reliable, the SR20DET is a pretty strong engine. Although it uses the same engine as the GTi-R, it doesn't have as much power but is still a fairly fast car. They're really tail-happy in the wet, and handle great with a bit of suspension work.
You say you wanted one with a Silvia front end ---- they call these "Sileighty's" .. You wont find a genuine one for $13k that is for sure. You may be able to find a fake one, but they're pretty rare too. The front end swap is easy, you should go talk to an importer about swapping/paying the difference for a silvia's front panels - they'll bolt straight up it's a do it yourself job
there's a buyers guide etc at www.silviaaustralia.com if you go have a look there. Also another thing to look for, if the 180sx you're looking at has a small wing which comes stock, look under the boot. They've got ****ty seals and water tends to get under there and stay there for a long time... you know what that means! RUST! so just check it.
So just have a look through the buyers guide on the link i gave you if you're after more info.. it's just like buying any other import there's a few usual things to look for..
all in all if you get one in decent condition they're a reliable car which can go damn hard with a little work
https://www.sau.com.au/forums/topic/1655-180sx/#findComment-32031
Originally posted by [ryan]
the ones with the rounded nose 1991 onwards have the same motor as the GTi-R, the SR20DET. Although it uses the same engine as the GTi-R, it doesn't have as much power but is still a fairly fast car. They're really tail-happy in the wet, and handle great with a bit of suspension work.
QUOTE]
Erm, NO the SR20DET found in the 180sx is NOT the same as the SR20DET found in the Pulsar Gti-R. For one the GTi-R version uses quad throttle bodies and as mentioned they pack around 30 kw more punch straight out of the box.
The standard issue SR found in the 180sx is still a great motor and reacts very well to mods.
note ryans "Tail happy" comment :( 180's drift with the best of them!
https://www.sau.com.au/forums/topic/1655-180sx/#findComment-32190
oooh ooohhh.. oooh...
180SX's look SICK!
'specially the newer (97+ models) Spec2 models... *squeal*
As far as my quest for a skyline goes, insurance/finance/cost, it seems everything under the sun is preventing me from a Skyline right now..... might just have to settle for a nice 180 me thinks..
as for teh pop-up lights, yes, VERY 80's.. I much prefer the Sileighty.... must organise a panel swap if i DO get a 180...
Also, my insurance will be cheaper as a result. It's all part of my new car project.....
... hence the fact, i want a new JOB!!! in IT! HELP!
... then a skyline would be SO much easier...
https://www.sau.com.au/forums/topic/1655-180sx/#findComment-34077
I can be patient, what are the details?
If not I was thinking I could just turbo my EB, dont laugh i saw an 11 second Falcon XE Turbo 4.1. On Gas. Looks like crap but goes hard. 338.9 rwkw and 1408.2Nm of torque, yeah thats right 1400.
I wouldnt go to that extreme but its cheaper than getting a new car.
You can check it out here www.fullbost.com.au its under feature cars.
https://www.sau.com.au/forums/topic/1655-180sx/#findComment-34565
  • 2 months later...
To get that kind of power out of your EB, will cost you more than buying a 180 :) and 100% more headaches.
Stick with ice180, he'll help you out.
https://www.sau.com.au/forums/topic/1655-180sx/#findComment-74433
180s are considered one of the best drift weapons in japan... i guess that says something, they also look ****ing sweet and go extremely hard, especially the sr20det beasts... another difference between the gtir is the size and location of the intercooler, it'll be easier to fit a larger intercooler to the 180...
failing that get an fc rx7... **** yes
lates
https://www.sau.com.au/forums/topic/1655-180sx/#findComment-75224
s13 silvia fronts are ugly as i reckon. stick with the classic pop up lites and a nice front kit. i definetly agree with NIZ30, the strawberry kit is nice. i've still yet to see one in melbourne.
the 94 onwards 180sx have the black rocker cover engines, same as 200sx. i use to have a 1.8 180sx, still like em, but i lurve the skylines!
https://www.sau.com.au/forums/topic/1655-180sx/#findComment-75670
    • Welcome Gabriel, and thanks for saving one of the less famous cousins!
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
