This R33 was imported from japan by myself in 2003 and has been extensively worked on over the last few years with Thousands$$ of dollars being spent along the way. It has been a project in the making and I have finally reached a point where i'm satisfied and would now like to offer it to someone else to enjoy. The car has been setup to not only look awesome but perform exceptionally well with 227 kw at the treads, it is more than enough power to drive on the streets.... very quick off the mark and there's very little turbo lag as i'm using a T3 with internal wastegate setup @ 13psi. The car has been meticulously maintained with only the best fluids and components being used, serviced every 3000 k's without fail, i've only put 20k on the clock since i've had it as its spent most of its time in the garage. The engine has been completely detailed in a viper blue and deep gold theme to also match the rest of the car. The interior has also been done in viper blue and alpine white theme. The exterior has a Nismo 400R bodykit along with an aluminium GT wing which has all been freshly painted in 2 pak paints.
I've just had it in Autosalon at this years F1 and also the first round at Melbourne.
some of the components used in the build up:
*100mm thick Drag Intercooler
*Induction Filter Kit
*Heat Wrapped 3" Dump Pipe
*Trust Exhaust - 3 1/2" to 4" to 5"(TIP) cannon rear muffler
*Malpassi Adjustable Fuel Regulator
*Racing Fuel Pump
*Dspec Oil Catch Can
*OS Giken Twin Plate Racing Clutch
*Greddy Profec B spec 2 boost controller
*Greddy Warning gauges - Boost & Water temp
*4 x autogauge's smoke series gauges
*Alpine Sound System - huge sound!
*GAB adjustable suspension
*18x9, 18x10 Genuine Schneider Rims (lightweight)
....list goes on!
Also, plenty of spares.
This skyline is immaculate
Genuine reason for sale... just purchased a house.
Price $19,900 ONO
Welcome to any offers!
Call me on 0421 821 162
Marin.
Edited by fantov
https://www.sau.com.au/forums/topic/165508-r33-gtst-m-spec-vic/
first off. awsome car. awsome price too. i'm in adelaide and would be in a position to buy in a few months! it will be long gone by then i know. but anyone in vic gets a dam bargain if they get this car!
Thanks Mate,
I seem to think so too... definitely a lot of man hours put in to get it where it is now... will be sad to see her go! I have two months to sell as thats when my house settlement is... you never know with this market atm... she might still be for sale then! Drop me call when your in the position to buy.
cheers.
Hey mate, was just wondering what that rear wing is? Looks awesome
Thanks bud, Its an aluminium GT Wing... Ive had the supports powder coated in Brembo Gold and the wing sprayed in a 2 pak viper blue... It came out real nice!
Still lookin for any decent offers on the car... I'm flexible in the price!
  • 5 weeks later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
