((NEW NEWS))
Ok this sunday is a go ahead with events of some nature going down at the gold coast
Meet Point: Springwood Crazys
Time: 1:30pm
Leave: 2:00pm Sharp
Stops: At the moment i say yatala Ill be hungry :P
Then will decide from there
Be there or not its upto you
Cheers
Adam
(((OLD NEWS)))
Hi all,
Seems to me im either too bored or either most of you guys are working sunday's, who knows but need ideas on what to do tommorow organise a crusie to spit Like usual or try something different organise a cruise to the lovely laid back Sunshine coast, Choice is yours ill be bored otherwise if we dont do nothing, or throw me some ideas on what you guys reckn we could do tommorow for a cruise event or bbq or something
Strictly EOI at the moment unless there is a definet interest and some ideas come my way cheers oh and names :(
Cheers
Adam
hey bro how about a cruise and a BBQ ? everyone can pitch in a lil and get the stuff before hand... OR down the coast sat nite stay over come back sunday arvo dinner head out get pissed ! .. something to get more people out and get them to stay longer i guess..
P.S tomm i wont be able to make it .. im free next weekend maybe we should plan something in advance and get numbers of people attenting.. im sure our usual crew are in for it !
I just got my car back and im gunna do a run through Samford valley and Mt nebo.
Meeting at BP Albany Creek.
Anybody feel free to meet up with me.
Meet at 03:00 pm leave at 03:30.
Edited by subzeroR33
nebo sounds tempting if it was earlier if we had more interest that is id be happy to go down the spit where is everyone
Yeah it sounds pretty tempting to head down the coast as there is a lot happening down there today with the hyperzone carshow and drifting. There seems to be alot of people heading down off other forums as well.
I just hate the police attention and the traffic jams down the Goldy.
2.30 depart seems a bit late?
Why not make it a 2.00 depart, and 1.30 arrive?
Jason
All welcome.
We will at least give 2hrs notice for people to get there shit together :( .
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
