  • Replies 53
ok i have chosen these!!! as someone is selling them! they are 19's!
what u think?
i think you love regency sooo much!! =P
2" > stock is all your allowed legally, so 19" = defect for your car (at least thats what i got told when i was on the phone to them the other week)!
but the rims dont look to shabby =)
edit: opps, didnt see 2nd page of you love regency posts before i replied =P
Edited by Fishpaste~
Koya Inoxs are fair nice but, 19"s - you not worried about scrubbing or ride quality associated with low profiles?
The ride quality between 19's and 18's are the same, as the tyre profile is the same (ie: 19's just have a bigger rolling diametre)
:thumbsup: Having the same profile & width as a 18" wheel on the the 19", guard clearance may be a prob & rolling radius will have changed. Also, if you have the same profile & just reduce the width (strech the tyre) the sidewalls won't be as strong, nor absorb impacts as well.
  • 2 months later...
bring this back up as i still havent got rims!! lol but wat do u think of these??
r lensos good?
i also want the axis hiro but tempetyres r sold out for r32 gtst!!! does anyone else know were to get them and also in adelaide?
cheers
im going to tyrepower for Lenso GT05's, but fricken got too busy and i was supposed to go 4 weeks ago and other things came up, now i have to wait a bit longer cause i bought other shit.
July is a good month anyway, tax returns will see rims on my car fairly quick.
    • The jack pad placement always had me scratching my head. I only have a small section to work with on both the E90 and E70 (and insert new project car here ) and I could see lining it up to be a bit of a bugger. For me, the E90 is just too low and needs small ramps and then the front centre jack point is a bit tricky to line up (it's half way down the subframe and about the size of a tennis ball, its really hard to see unless your head is on the ground), so I definitely like the idea of not having to do a multi-stage jack and just sliding these bad boys in under the sides. There's only one small point at each corner, so I can't jack AND add a stand on the same corner. Or, maybe I can and I'm too nervous to try. 😟
    • Is this not the biggest deal of all? I was hoping the whole "will slide under cars with skirts etc and lift evenly quickly with minimal fuss" was the entire point of such a device?
    • Here's Neil's car up on mine recently
    • Yeah I've got one of these, Quick Jack not Quick Lift, but your link looks like a good copy For me, it's better than no hoist, but it is definitely not as good as a hoist  It lifts the car about 60cm which is a nice working height compared to regular stands and it is only under the sills so it doesn't get in the way like regular chassis stands do.  No need to use regular stands, it has a safety lock on it. On the down side it is really heavy/unwieldy to drag into place, and you have to place it after the car is there (no option to drive the car to where the frames are. You need to try and line it up with the proper sill points which is hard as it swings up in an arc and there is surprisingly little adjustment in the distance between the rubber pads for different car lengths. Not a big deal, but in practice a jack + stands is probably quicker. Also there are hydraulic lines to each side and you need either a 240v or 12v source to power it depending on which option you have, I use 12v as I always seem to have a battery around.
    • Finally addressing my catch can and oil setup Plan is to do as much as practical without having to remove the motor or pull it apart. (no back of head to sump drain/breather or oil restrictors) First step is a set of full length baffle plates from Hypertune and a Tomei cam cap stud kit. I could probably have laser cut and bent up my own ones but this took any guess work out
