As Title R33 series 2..........whole car wrecking........
Complete engine with turbo 53klms on clock (SOLD)
headlights (sold).
SELLING EVERYTHING NOW, PM ME IF I HAVE FORGOTTEN TO ADD TO LIST
SERIES 2 STUFF:
s2 bonnet $400
manual s2 DIFF $400
Front seats $300
complete Back seat $200
Dash speedo / klm etc complete $200
Gaurds $140 each
Doors $200 each
boot lid $150
series 1 boot lid spoiler $75
Taillights $120
Complete airbag set/dash/ 2 airbags/sensors $1500
Complete 5 studd conversion / hubs / rotors / calipers all what u need ...$900
radiator support $200
front bar $300
SERIES 1 STUFF:
R33 series 1 Bar complete $200
R33 series 1 reinforcement $200
R33 series 1 bonnet $200
R33 series 1 headlights $400 pair
R33 front bar blinkers $100 pair (will separate if needed).
Thats all i can think off at moment.
IF NOT ON THE LIST ABOVE LET ME KNOW WHAT U NEED AS CAR IS STILL MOSTLY COMPLETE.
post here or PM me / If u want let pics let us know and i will email them or post here later.
SYDNEY. but willing post / courier.
Edited by livicuru
https://www.sau.com.au/forums/topic/165569-r33-series-2-wreck-series-1-front/
  • Replies 95
What aftermarket parts, if any?
the car was pretty much factory standard mate.
However, i do have a new trust bomex front bar (not painted yet, just triall fitted) for s1 and vented guards for sale. separately.
Bomex bar $300
vented gaurds $300 pair too. These are new also.
I may advertise them or just add them in to this post later.
Edited by livicuru
Do you have:
1. Plastic surround that goes around steering wheel and CD Player.
2. Left hand side plastic piece that runs underneath the door that says “Skyline”
For a R33 GTS-T Series 1. Please PM me.
Hi Mate, I am after the diff. Can you mplease tell me some more.
- where the cv bolt on to the diff is it 6 bolt if yes are the bolts evenly spaced or in pair.
- Does it have the ABS sensor on the diff near the tail shaft
- I may also need the axles if it is not a 6 bolt
Please advice if possible to come and have a look.
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
