When Were You Pulled Over?
davib
 Share
When my car was actually working, I got pulled over every night before and after work, sometimes twice.
I live around Hornsby and work in the nightclub that goes till daybreak so fair enough they are always pulling me over for RBTs but I just wish they would learn my damn plates and leave me alone.. It got to the stage where they'd come up alongside and go "Oh it's you, all good then" and toddle off back to their car and leave. The only time they ever had good cause for pulling me over and yelling at me good and proper was for leaving a carpark sideways(stupid) cos I'd had a bad night.
I have just worked out that i sort of know you
as i drink there and have seen your car
i didn't know you were on here
i'll say hi next time i am in there
undercover pulled me up @ 5pm today
"RBT" then said my eyes were red and glassy
and asked if i was on medication?
loser
but he said he liked the car :P
Haha hey mate, pretty sure I saw your car parked in coronation street last week? Do you have white rims? I have a friend named Ash who also drives a black R32GTR around the area so I never know if it's his or yours.
By all means come in and say hi, I'm the one who runs around the place looking after everything :D My name's Steve
And yep you've probably seen my black R33 parked out the front, rego plate is UPB33T. It's off the road at the moment getting a major upgrade but it'll be back soon, cya round! :)
Edited by Zilch*
only ever been pulled over for something stupid once. the usual, a bit too happy off at the lights. he was a nice guy who also owned a skyline.
every other time has been an rbt station or mobile... although i think i got picked on one week. 4 rbt's in one week on the same 300m section of road in round corner dural. :)
havent been fined for anything though. had the car for about 2 years now
Only been pulled over once in the line, was in the afternoon, just before xmas, had a RBT set up on the side of the road, stupid me was behind a truck, and i didn't see em until it was too late, i had a DVD playing at the time. Cop asked for my licence, checked it out, gave it back to me and told me to have a nice day.
I've mostly (90%) been pulled over at night at RBT stations, only been "randomly" pulled over once, back when i had my Lancer.
Went for a drive from Bondi to Coogee and back to see what the cop situation was like after the riots when cops had beaches on lock down..
Pulled over 34 times :laughing-smiley-014:
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
