These babies have been around for ages and are now extinct, except for the 2nd hand ones floating around which I've grabed and installed.
....It seems that nearly everyone has got over excited and posted results on the standard injectors/AFM stage and hit around the 230-240's on about 1bar/14psi....but then if they went any further, forgot to put those results up?
I've been searching for ages and can't find anyone with a solid 17psi dyno with some decent injectors/fuel pump/AFM and the usual supporting mods.
Is there anyone?
Post em up peeps!
I'll be going the 17psi in a month or too and will post it up.
Just itchin to know how people went in the meantime.
Thanks.
Birnie
https://www.sau.com.au/forums/topic/165596-want-some-solid-hks-2535-results/
  • Replies 97
Posted Images
I scored 240 @ 17-18psi but running really, really, rich. (stock ecu with central 20 chip)
gtr fuel pump, stock injectors, adjustable fuel reg n other supporting mods
Waiting to get the power fc tuned, and i will keep u updated
2535? best thing in my life :):(
edit: rb25 :)
Edited by DjeMz
edit: rb25 :)
Now we're talking!
Geting some good results coming thru, keep em coming..... :)
DjeMz - What are you doin man!
Get an ECU and see your car come ALIVE !
cln, rob told me no one ever believed it and he did it a number of times to shut people up..
Justin911 is now using that turbo.
And no it wasnt 25psi thru the turbo.
DjeMz: Robs tuning wont disapoint you :)
djemz: rob from creatd is confident 2530s and 2535s are good for 250 and upwards.
with a 2530 he made 255 on his drift 33
Happy dyno??
Worth a review of published data from Garrett. Considering the GT28RS (aka Discopotato) with flow maps and a compressor spec near-as identical to the 2530 is rated to 320 CRANK hp, the claim seems a bit high.
Still, if that's what he got, and it's backed up by times down a strip or round a circuit, then who cares? Great result if that's what he got.
nope not a happy dyno at all, rob doesnt mock up his figures :)
He used it for drift and used to tear up 3rd gear like you wouldnt believe.
Its a HKS turbo, HKS turbos flow better and are better than the hks turbo, said by many many tuners i have spoken to.
Has these figures been backed up on another dyno? Did Justin run his car at the SAU - RE Customs Dyno Day, if so what did he get?
260rwkw on a gt2535 is optermistic and claiming anything higher is just BS.
Should convince Justin to come to a SAU dyno day :(
320hp = 246.4kw at the crank @ 1bar
drive-line losses is about 30-40kw. Running 17-18psi may give you an extra 30-40rwkw, but remember this is a smallish turbo, thus will not make much more power at higher boost levels above 18psi.
was reading a old hks book the other day noticed that hks's 320 p/s power fig for 2530 is running them on only 1 bar
as was p/s ratings for 2535,2540 etc
so at 1+bar they will make more grunt period
remember HKS turbo's are manufactured to be most efficent at 1-1.5 bar
:santa:
Should convince Justin to come to a SAU dyno day :thumbsup:
I did the same before but assumed I was wrong Al.
340hp @1bar is on close to the edge of its efficency. Bump up the boost wont yeild massive HP gains...just some more torque.
~250 seems possible on 18psi as suugested. His drift car must be running more boost and have some decent internals.
Eitehr way its gonna be a good result from the upgrade.
past 240rwkw i dont think you will make any more power
every extra psi you dial in just induces more detonation and bugger all power per psi past 1 bar
the compressor probably cant supply any more useful past 1 bar of compressor speed
then how do people make 290 - 300 kw with a gtrs so iv read on this forum?
They don't. Dyno read outs don't mean shit unless you run all the cars on the same dyno, on the same day.
I have a HKS GTRS, with extensive head porting and Tomei cams. Boost was set to 18psi, but b4 peak power it dropped down to 16psi and made 268rwkw.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
