i have the 2530 strapped onto my rb20 atm with a few other supporting mods.
as soon as a dyno day comes around, it'll be on the dyno getting a power figure. hoping for around 200kwrw on about 1-1.1bar.
gotta sort out the running rich issue first tho.
  • Replies 97
Posted Images
Which ecu?
If you cant afford a pfc to fix the rich issue, try a SAFC?
Just for the record those HKS GT2535's are really just a 2530 with a slightly larger dinosaur 6/12 blade compressor tossed in because Garrett weren't doing the 71.1mm GT35 series compressors at that time like in later GT2871R/GT-RS type turbos . If you got a GT2871R 48T and bolted the HKS T3 flanged turbine (exhaust) housing to it you would have the same approximate deal with a more modern compressor wheel .
HKS got into Garretts GT ball bearing turbos early and for this reason had some combinations of mainly compressors that they don't use today . This is why turbos like 2510's , 2535's and 2540's are no longer made , better combinations developed with later thinking has made them redundant .
Roll on the twin scroll twin integral gate turbos like IHI is supplying to Subaru because they are the way of the future .
Cheers A .
My RB25 HKS 2535, combo made 244rwkw 14psi stock inj and AFM running a PFC.
I then bought injectors, Z32 boost controller etc, no more peak power but a massive amount of midrange was gained from 18psi... The extra boost totally transformed the car!
That same turbo is now on a mates car running 250rwkw at 15psi (i think) with the same setup (ECU, Z32 etc)
I also have another mate with a HKS 2535 on an RB25 with a Wolf 3D, injectors etc and he is running 18psi and 252rwkw...
I dont think they will run much more than 250ish rwkw no matter how much boost they have but the midrange agin on them is amazing at high psi...
I have one of these babies too on my rb20...made 202kwkw at 15psi with ths usual support mods...exhaust, fmic, fuel pump, z32, injectors and remapped ecu...theres a fair bit more left in it i just need a new front pipe as mine is dented and would be restricting flow...also have a 3" metal cat coming in the main to replace the sh!tty 3" cat i have...will turn the boost up and do another tune...then we'll see how it does....
Edited by limpus
Just to add a little further,
HKS 2530 equivalent = GT2860RS = 60mm compressor = 320hp rating
2535 = 69mm compressor = 350-370hp rating, no direct spec equivalent from Garrett
Garrett 2871 48T = 71mm compressor = 380hp rating, no direct spec equivalent released by HKS
Garrett 2871 52T = 71mm compressor with bigger inlet + T25 turbine flange pattern = 400+ hp rating = HKS GT-RS (but this has T3 flange pattern)
Running beyond a compressor's flow capacity will yield more midrange torque for sure, but run them into choke and as everyone's saying you won't make any more high rpm torque and possibly strike detonation issues unless the tuner takes strong notice of what the mechanical specs are and what information is being logged during the process.
Bottom line: do the numbers really matter, or what it does on the road?
Edited by Dale FZ1
robs was a 2535, not a 2530 :domokun:
my 2535 makes about 248kw @ 14-15psi according to what the dyno rekons.. allthough it does sound abit high.....
cln, rob told me no one ever believed it and he did it a number of times to shut people up..
Justin911 is now using that turbo.
And no it wasnt 25psi thru the turbo.
DjeMz: Robs tuning wont disapoint you :)
Im also using a HKS 2535 with a power fc, After market fuel pump, Splitfire coil packs 3 inch turbo back exhaust, GFB bleed valve standard injectors and sandard AFM on a RB25 R33 Series 1 the car pulled 240 rwkw at boostworks
Here is what you said:
djemz: rob from creatd is confident 2530s and 2535s are good for 250 and upwards.
with a 2530 he made 255 on his drift 33
When in fact 250rwkw is about the limit for this turbo; NO "upwards" :P
I just stated "260 is optimistic and any claims more is just BS"
Here is my Dyno graph with a before mentioned set-up.
Ignore the red line as the graph is a "b4 and after" comparison when i changed my exhaust system.
You can see where the cams and porting come into their own: More usable power and torque (better average power and torque)
I consider the GTRS as the newer version of the GT2535, as it only makes slightly more power and they stopped producing the GT2535 when the GTRS was released.
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
    • WRXs are a pure pleb boring car these days. You need to get an STI to even get close to what a WRX used to be.
