  • Replies 97
Posted Images
The HKS GT2535 is a great little turbo, one of my customers is running one on an stock RB25 and one 13PSI made 210rwkw, and previously on an RB20 he was making 197rwkw on ~1bar. In regards to the clutch unless it comes in boxes like pictured below it's not a genuine Exedy:
Grrr, pretty psssed off right now.
I'm a bit over mods and was happy to just enjoy my car.
There's $440 on a under-par clutch with $400 installation down the &^%&^%ing toilet
Thats really bad man. What pressure plate is it & what box did yours come in and did it have a new thurst bearing with it?
Thats exactly what I picked up yesterday.
5 PUK Brass button clutch, I think something like 1,200kg clamping pressure for the pressure plate.
Comes with new thrust bearing as pictured.
Edited by abu
I had a 2535 on for a year. Great little turbo but god knows why you guys don't put some more boost in it. Running low boost it doesnt feel
anything special, nice progressive power, but nothing sensational. Dial in 20/21psi and it transforms the car significantly. You get midrange
that feels so leathel on the road. Comes on nice and strong in the middle and you don't have to ring its neck out to get power. Use the torque
in the middle. Enough to propel my car to a 12.1@116mph in full street trim.
Somebody asked about the VG30 hybrid ( or R34 GTT) high flow turbo from GCG.
I make a comfortable 250rwkw from mine on the RacePace (read conservative) dyno.
Poncams and all supporting hardware fueling.
The best thing is that it has about 100kph of power and boost.
Makes more than 240 rwkw from between 165kph and 210 kph.
That's what you call FAT
PS. More to come from that setup too, marginal top end gains now that my fuel supply probs are sorted.
Benno tells me that there is very little in it though as the engine is Choked by the exhaust housing. Looks like the back pressure in the exhaust manifold is just pushing the wastgate open and we can't keep stable boost over about 5000rpm.
Discuss. :thumbsup:
Supposed to be a 1200kg pressure plate but the pedal feal is softer than standard
(don't know if that marries up to the pedal feal though)
The box was plain white. The left bit (haha, bell housing maybe?) was not pink and i got the Cushion Button kit for 260rwkws rated. 245 and slipping ????? I would expect to be able to go higher than the rating.
Who would rate clutch higher than what it can handle, you think they would under estimate to cover themselves....geeze.
Haha, yeah i know, you told me soo.
I'm happy with the punch i have now, its pretty good :thumbsup:
Only 2-3psi off your figure.
Also had the spark issue and i don't wanna cough up for Splitfires.(assuming i would have had spark issues if dialing in more boost)
That’s not right at all..
I have driven 3 x cushion buttons and 1 x brass button.
The cushion buttons felt a lot more firmer with more pressure for some reason, and the brass button which was also in an R33 feels very light. The pedal it self isn't heavy but has a firm bite.
The cushion button I drove in the R32 was very heavy compared to the brass button in the R33, roughly twice as heavy, so not sure what the go is there?
But like stock? That cannot be right. I think the full-face organic clutches are slightly heavier than stock, cushion button the next one up from that, then brass button.
Contact SLIDE and ask him what the go is, definitely something sus I reckon.
There is no way that a cushion button can be lighter or as light as a stock clutch!
Edited by abu
Yeah spark can be a problem. More boost means more spark blow outs. You have to balance the boost and the spark plug gap.
18psi is getting better, much better than 14.
I'm pretty happy Robo.
Never been to the drags but might have to, to see how it goes.
It's definatley got the midrange 'yeeehaarr' happenning.
I've sent SLIDE a PM about my clutch issues.
No idea what will happen there ?
How do you prove what you have without removing it?
Birnie, you might want to contact Jim Berry Clutches actually. I reckon he sells the best clutches in the market for a good price as well. I'm actually going to purchase a clutch which can support at least 300rwkw from him soon. Well, that's IF you're going to buy a new clutch :D
Yeah thanks, i knew about his but i would have thought 250rwkws to be conservative considering the figures thrown around these days. So a Exedy should be up to the task.....hmmmmm
To spend another $500 or so plus another $400 installation is rediculous.
I've got my PM response which is to remove and send it back for inspection by Exedy and then get a replacement if it's not up to scratch.
How am i or anyone else suppossed to do that?
Now looking at buying a second car so i can do all this bullshit.
Figure out how to remove it myself and send it back.
This is rediculous amounts of dollars down the toilet
thats a bitch mate. The thing is how do you prove it's not up to scratch? Exedy could just say that it was abused etc. Thats the problem with high performance cars and clutches. They might replace it but you dont know till it comes out etc. I guess they will check the claming force etc.
Either way you're looking at the labour. I think when I get my clutch done I might end up buying the clutch from the person installing it - then atleast there is some chance of recouping labour cost if clutch is not up to spec.
Sorry to hear your dramas. Just be careful if you do it at home..it looks like a heavy gearbox and not much clearance under the car. A few people on the forums would have done a clutch change at home - maybe it isnt that bad. Ive done a FWD one before that wasnt too bad. I think though for $350 to $400 I might just pay someone to do it if clutch needs replacing.
Apparently, if I am not mistaken, EXEDY don't offer warranty on performance/racing/sports clutches, only on standard replacements?
I'm sure the clutch would have held up fine witht that power if he actually got what he paid for.
I think the cause of all this is the pressure plate it self, not being an EXEDY pressure plate.
Edited by abu
  • 1 month later...
Talk to a clutch specialist first, they might be able to save you some time and worry.
If its the pressure plate not been up to the task you can bump the clamping pressure up. A clutch specialist will be able to do this for you. I have a nismo pressure plate (exedy) rated at 1200kg and they said they can put it to 1400kg.
Good Luck
Cheers
    • You’ll want to have the block drilled and tapped to suit 1/2in head studs and the head for the same. How much power do you intend to make?
    • Sorry for resurrecting an oldish thread Not much has happened in the past year since the last update. The car did another 1000 miles or so and failed the MOT for the first time in October (failed on tyres which had been advised for a couple of years) In October the car got put up for sale and was removed in November due to no interest, being so close to christmas it was to be expected. The roads were dry in February so I decided to tax it early and get the new tyres fitted.   Fast forward to April, I got someone in to give the car a good clean after sitting for the winter.                                 The car got re-advertised and today (Saturday 3rd May) the car sold. The new owner is planning a GTR conversion at some point and a respray in the same pearl white. It's bitter sweet, it's a shame to have the car sit there for half the year and then only do 1000 miles. The kids are growing too quick and space in the back is getting limited. It's been a great 6.5 years of ownership
    • And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
    • No cats will keep discolouring the rear bar. Sends white paint a weird yellow stain. Cut and polish normally gets it out, but you'll be doing that every fortnight I found.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
