Hey looks like I may have an issue with my tailshaft, as im getting vibrations from the rear at about 60km/h. Not as noticable outside this.
I have taken it to a knowledgable mech and they narrowed it to realignment the tailshaft. I spoke to some guys who specialise in Tailshafts and they said normally the middle bearings are shagged (r32 gtst).
Has anyone realigned and/or replaced the middle bearing of their tailshaft? Im just after rough costs at this stage. Cheers.
https://www.sau.com.au/forums/topic/165602-tailshaft-issues/
The actual bearing is only around $30 i believe... i was looking into it a while ago on my car..
turns out the gearbox was causing the noise.. not the centre tailshaft bearing
Itd come through his streering wheel if it were that.
A mates VK did this same thingvibrated under load.And because he never had it fixed,after doing so many burnouts it would spit a universal joint once a month.So he used to carry a spare with him.Rofl.
Ive been with him when he has had to replace them on the side of the road.
Only if it's the front wheels that are unbalanced. He said the vibration was from the rear. Steering wheel not connected to rear wheels directly.
Abobob - so ur saying the wheels could be causing the vibrations? No i havent tried that
Took it to a tailshaft specialist workshop today and they said the centre bearing and mounts are fine, and they said its definately one of the joints which need replacing.
They said might as well change it to a 1 piece tailshaft for $400.
Bloody expensive. Anyone have any tailshafts for sale? or know where i can get some?
hmm damn tailshafts.... we had a rear uni break on cats 26'd S13 a fortnight ago on CREATD's new dyno @ 6700 rpm...... fkn scary as i was sitting where the rear seat is usually with the laptop. The tailshaft tore through the floor and missed my ass by about 10-15cms.
Moral: unis are cheap asses are not :rant:
Edited by URAS
    • If the RB29 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
